586,106 active members*
2,966 visitors online*
Results 1 to 6 of 6
    Jan 2021
    19
    Alarm Operating switch fault Mazak QT-20
    Hello everyone!
    We recently acquired an older Mazak QT-20. When powering the machine up, it displays alarm 350 Operating switch fault along with an estop alarm. Web research says that it could possibly be an operator panel switch. When looking at the I/O and pushing each button, we see that everything is working. Does anyone have any suggestions? Can someone post a picture of their I/O Monitor after startup? Attached is a picture of the machine I/O screen.
    Thanks for any guidance!
    Sep 2012
    216
    Re: Alarm Operating switch fault Mazak QT-20
    You could try the chuck clamping switch. That's not normally the error you would get for that but worth a try. Are the doors closed? Can you home the machine or nothing?
    Regards Bob
    Jan 2021
    19
    Hey Sudsy! Thanks for the reply! I’ll double check that door switch to make sure it’s making. The chuck clamp switch doesn't move the chuck. All buttons switch in the i/0 screen but the machine is unresponsive. The machine won’t move or home or anything.
    Edit: on second thought we never checked the chuck foot switch in the i/o to see if it’s working. Will be doing that also!
    Thanks!
    -Will
    Sep 2012
    216
    I meant the chuck direction switch. The one that is for either internal or external. Not sure what control you have but it will be in the little door with the RS232 connector on a T32 control and in the back electrical box on a T1. I don't know about other controls
    Regards Bob
    Jan 2021
    19
    Hey sudsy, I checked both the door switch and tried switching the chuck direction with with no joy. Any other suggestions?
    Thanks!
    -Will
    Jan 2021
    19
    Figured it out! Turns out you need to have your foot on the chuck foot switch when powering up the machine. Is this normal?
  1. Need operating manual for SQT-10MS Mazak
    By RRaly in forum Machinery Manuals / Brochures
    Last Post: 03-17-2021, 07:07 PM
  2. Limit Switch Fault setting up G540 with Mach3
    By cuttingchips in forum Gecko Drives
    Last Post: 04-26-2013, 02:16 AM
  3. EZ Path II Lube Pressure Switch Fault
    By speedracer50 in forum Bridgeport / Romi Lathes
    Last Post: 01-17-2012, 06:00 AM
  4. Error 10 overheat 350 operating switch fault
    By casco in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-17-2009, 01:28 AM
  5. Mazak operating manual
    By cnc_swe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2008, 11:23 PM
