586,036 active members*
3,612 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How would you hold this workpiece?
Results 1 to 10 of 10
    Post How would you hold this workpiece?
    Hello All,
    I am having trouble trying to run a 2nd-op on this part that is shown in the PDF. All I have to do is face off the backside, but I have yet to find a way to cut soft jaws without it torqueing or bending. Is there another way you would recommend or what point of contact for the soft jaws would you use? Please help, thanks!
    Apr 2004
    5737
    Re: How would you hold this workpiece?
    There's this stuff that jewelers use for holding onto irregular parts, it comes as loose beads of plastic that you put in water and melt in the microwave or over the stove, then form around your part. It can be reused indefinitely, as long as you don't contaminate it. Form it into a square on the outside, and you can hold it in your vise or 4-jaw chuck. https://www.riogrande.com/product/je...ompound/118221
    Andrew Werby
    Website
    The compound will be rigid enough to hold onto the part and clamp into the vise and machining? I have never heard of this compound. Thanks for the feedback!
    Apr 2004
    5737
    Yes; it sets up as a solid block of plastic.
    Andrew Werby
    Website
    15362
    Quote Originally Posted by Antvillareal View Post
    Hello All,
    Profile the soft jaws for the whole part have about .005 clamp max when the jaws are completely closed
    Mactec54
    I would need microsized endmills to profile the part. I have tried a few methods already to bypass them but it still torques up with any tightness of the vise and bends easily because its 6061 aluminum..
    cut deeper than needed then cut it off with a slit saw
    15362
    If it changes shape then you don't have your profile cut correctly, you can also make a block that your part fits in and hold that block in the vice
    These parts where all machined and are much smaller than your part and where all held in a vice with fixtures some easier than others to do, just for a size the hole in the ceramic is only .020" the ceramic round parts where a lathe machined part
    Mactec54
    I think Metal has solved your issue. I make a part with .4mm wall thickness and I do it exactly as he suggests. Since the part is small, it should be a breeze with the slitting saw.
    the nice thing about using a sit saw is it works well and it eliminates a whole other operation , If a chamfer is needed on both sides of the part then a dovetail will take care of the bottom side . . My preferred way is to slit half the part one way then slit the other half from the other side leaving only .005-.01 to hold the center . I find he parts have less tendency to break loose while machining if it's held by the center of the part , but , that may also depend upon the part
    If your doing a lot of those parts then match up as many as you can to say a 12" bar then cut them , slit them , done , aside from a bit of hand sanding
  1. Little space to hold my workpiece on
    By lindum in forum Milling
    Last Post: 10-12-2019, 02:15 PM
  2. Setting workpiece zero with G10
    By MRPM in forum Mori Seiki lathes
    Last Post: 03-24-2017, 03:04 PM
  3. Hold to hold tool holder while loosening nut
    By NXTwoThou in forum CNC Tooling
    Last Post: 02-24-2009, 10:15 PM
  4. How to hold small workpiece?
    By kad2kam in forum Uncategorised MetalWorking Machines
    Last Post: 07-29-2004, 07:08 AM
