586,058 active members*
3,967 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > 30hp submersible elevator motor for phase converter?
Results 1 to 6 of 6
    Feb 2014
    9
    I have EZ30S1BZ NIDEC motor. I'd like to use it to power my fadal 15xt. It is an open frame design and it only has one bearing on one end.
    My thought was machine a cap eith a bearing for the pump end, build a small tank for the motor, and enjoy a quiet phase converter.
    Has anyone dealt with this type of motor or see any flaws with my idea?
    15362
    Re: 30hp submersible elevator motor for phase converter?
    Quote Originally Posted by Wilde Racing View Post
    What is the Hp of your spindle motor, what ever that is you need the RPC to be double the Hp rating of the spindle motor
    Mactec54
    Feb 2014
    9
    It is a 15 hp peak 10 hp continuous.
    15362
    The motor you show in the photo is only 10Hp that would not be big enough to drive your mill, plus a RPC must have a balanced power output to run a CNC machine
    You would need a 30Hp RPC and a Single phase supply that could run it, you may get away with a 25Hp RPC
    Mactec54
    Feb 2014
    9
    It's a bad picture but that is a 3 not a 1. The model number also lists it as a 30 hp via web search.
    15362
    Then that would be fine if you can get it all together and get a balanced output on all 3 phases
    Mactec54
  1. 30HP Phase Perfect PT-380 Forsale--Low Hours-GOOD DEAL
    By camarogod98 in forum Phase Converters
    Last Post: 08-04-2021, 08:38 PM
  2. Replies: 3
    Last Post: 12-10-2020, 07:15 AM
  3. Replies: 0
    Last Post: 02-03-2017, 07:22 PM
  4. DM4400-what size 3 phase motor for rotary converter
    By drhanger in forum Dyna Mechtronics
    Last Post: 02-03-2017, 02:54 PM
  5. 30Hp phase perfect convertor large enough for a Qt20 ?
    By elohim1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-27-2011, 09:37 PM
