586,069 active members*
3,353 visitors online*
    Apr 2019
    5
    Memory card not exist!
    I want to take SRAM backup to USB pendrive on Fanuc CNC lathe machine.
    Model number Oi Mate TD (D7 F1-34.0).
    System Monitor Main Menu shows 'Memory card not exist', though i have changed I/O channel 17 and pendrive is plunged in.
    Should i change any parameters to take SRAM backup to USB pendrive?
    Can any one help me about this problem?
    Apr 2009
    108
    Re: Memory card not exist!
    I am a little confused by the title "DRPINT IN MEMORY CARD....".
    From what you described, it sounds like you want to make an SRAM backup of the machine memory to a USB device? This is normally done in the boot screen using a memory card. The boot screen does not support USB.
    You can make an SRAM backup to a USB device but you will need to boot up in IPL mode.
    Hold " - " (minus) and " . " (decimal) in while booting up. It takes some time for the screen to appear so be patient.
    Select BATCH DATA BACKUP / RESTORE (12)
    Select BATCH DATA BACKUP CNC TO USB MEMORY (11)
    You can also restore the SRAM from IPL
    Apr 2019
    5
    Shoprag
    Thanks a lot.
  1. Replies: 2
    Last Post: 08-22-2023, 07:52 PM
  2. 2041 2 NO program does not exist in memory
    By witbike in forum Hyundai Kia
    Last Post: 10-23-2017, 04:29 PM
  3. Vid card or memory
    By Gallchobhair in forum BobCad-Cam
    Last Post: 01-15-2014, 07:44 PM
  4. 21i-MA - Memory Card
    By aaronson in forum Fanuc
    Last Post: 08-12-2010, 11:03 PM
  5. Memory card
    By M-man in forum Fanuc
    Last Post: 07-17-2006, 09:00 PM
