586,675 active members*
3,026 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > FRD-700 and Chinese 1.5KW Chinese Spindle motor
    Feb 2005
    149
    I need a littler help please.
    I screwed up my settings om my FR-D700 Mitsubishi Frequency drive.
    I'm using a Chinese spindle motor 200730184245.5 rated at 8amps 400Hz 220V 2pole 24,000RPM,
    Can anyone remind me of the FR-D700 parameter settings for this motor please.
    Kind regards and hope you are all safe and well.
    George
    Feb 2005
    149
    Re: FRD-700 and Chinese 1.5KW Chinese Spindle motor
    I have managed to get my Spindle motor running again but it would be good if anyone can check my settings please. Here's what I have
    Parameter Number followed by value set followed by descriptor
    0=4 Torque boost
    1=400Hz Max freq
    2=0Hz Min freq
    3=400Hz Base freq
    4=400Hz Hi Speed freq
    5=30Hz Mid Speed Freq
    6=10Hz Lo Speed Freq
    7=5 Accel Time
    8=5 Decel Time
    9=8 Motor rated Amps
    10=3 Brake Freq
    11=0.5 Brake op time
    12=4 Brake op Voltage
    13=0.5 Start Freq
    14=0 Load Pattern select
    15=5 Jog Freq
    16=0.5 Jog accel time
    17=0 Mrs input select
    18=400 Max Hi Speed Freq
    19=888 95% rated motor voltage
    20=50 Accel ref Freq.
    Should there not be a setting for motor Voltage somewhere ??
    George
  1. Spindle Motor for Chinese CNC
    By AngelCarr in forum Want To Buy...Need help!
    Last Post: 04-13-2020, 02:22 AM
  2. chinese 2kW spindle motor repair
    By reg.miller in forum Spindles / VFD
    Last Post: 03-06-2020, 10:24 PM
  3. Chinese CNC 3040T Slow Spindle Motor
    By Viking50 in forum Chinese Machines
    Last Post: 09-05-2013, 07:06 AM
  4. WTB (Chinese) Spindle motor & VFD 1.5KW U.S. Shipping only
    By bodabalina in forum Want To Buy...Need help!
    Last Post: 03-10-2013, 02:23 AM
