586,096 active members*
3,675 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics VM25 C7 2003
    Oct 2014
    8
    Hello
    I have Milltronics VM25 C7 2003 , recently having issue with M19 spindle orientation . I have been told by Milltronic Service , it seems Spindle Motor is failing and need to be replaced. looking for feed back and suggestions?
    thanks in advance
    Jul 2010
    548
    Re: Milltronics VM25 C7 2003
    Hi Mill, you most likely have a Yaskawa spindle motor / drives/ the motor has an encoder that is used for spindle speed and the orient position. the orient position s send to the spindle drive " orient board" then is translated to stop at the programmed orient position. It might be an encoder, or orient board or a spindle drive problem.
    You will need a meter to run some checks.
    Give me a call so we can run some checks.
    Sportybob
    952-288-6340
    Oct 2014
    8
    Hi Bob
    the problem is there when the motor is cold , as the motor warm up and running , it get better . so on that base i was told the motor is failing .
  1. Tool changer recovery VM25 7 control
    By positiverake in forum Milltronics
    Last Post: 05-24-2019, 02:15 AM
  2. 2003 vm25 7 control
    Last Post: 05-02-2019, 02:40 AM
  3. 2003: Arm 60D m/c lock?
    By markamara in forum Fanuc
    Last Post: 02-08-2012, 11:17 AM
  4. Need help importing SW 2003 into BCC v.24
    By jjayharrison in forum BobCad-Cam
    Last Post: 06-21-2011, 01:07 PM
  5. Need Help With Intellipost-2003
    By charlie huffman in forum Uncategorised CAM Discussion
    Last Post: 06-30-2007, 05:34 AM
