586,055 active members*
4,176 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF-OE -- I/O PCB -- where do these connectors go???
    Please see the hi-res photo here: objectivelyspoken.com/uploads/20210124_142711.jpg
    This is a machine just delivered to my garage that I have yet to power up.
    Before the machine was moved, the technician removed the Regen Resistor Box at the top of cabinet. This means he disconnected the regen cables. I have now connected the regen resister cable, and the regen overheat connector on P20 (above P15 on the left). According to the Mitsubishi spindle drive instructions the Regen Resister connects to P and PR so this seems where it should go.
    Now I have noticed there are four 3-pin male connectors on the right side of the IOPCB that are bare:
    They are P57, P58, P5(110), and P54(350).
    There are also 5 female connectors hanging loose. (You can see them hanging on the right just in the shot.)
    Er...did the technician remove these to get the Regen cable loose?
    Must I plug them back in?
    Does anyone have a shot of their cabinet they can email me showing what is plugged in and what is not.
    This is a 1996 model. I don't yet have three phase power installed.
    Paul
    Aug 2005
    114
    Re: Haas VF-OE -- I/O PCB -- where do these connectors go???
    Paul,
    Ask this question in the HAAS forum section on Practical Machinist website. There is a larger group of Haas owner operators there to help.
    JW
    Quote Originally Posted by jxdxwx View Post
    Paul,
    JW
    thanks!
  1. What connectors do you use?
    By Fortdick in forum Benchtop Machines
    Last Post: 09-06-2015, 06:25 PM
  2. 6 pin connectors
    By steeltoes in forum Want To Buy...Need help!
    Last Post: 07-11-2011, 05:48 AM
  3. Haas Cable Assembly Connectors
    By Mr. Technical in forum Haas Mills
    Last Post: 06-03-2010, 09:14 PM
  4. Connectors
    By LaserImage in forum CNC Machine Related Electronics
    Last Post: 07-10-2008, 06:53 PM
  5. DB-25 Connectors
    By Nmbmxer in forum CNC Machine Related Electronics
    Last Post: 10-17-2005, 01:05 AM
