586,052 active members*
4,425 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > mach 3 each axis is "growing" while jogging or moving.
Results 1 to 6 of 6
    new problem I have never seen. I set my steps right but EVERY time I jog the axis it moves .12-.25" farther along in x positive. it also does this in y axis in the negative direction and the z axis's both gain in zero.
    its an older cmt machine with technic servos and drivers. I am using a break out board with mach 3 and an arduino to control the home switches/limit switches.
    the "growth" is always in the same direction but not always the same amount.
    I really need to run this machine. Im sure most guys here have been in this position.
    Apr 2004
    5737
    Re: mach 3 each axis is "growing" while jogging or moving.
    What makes you think you set your steps right? How did you go about it?
    Andrew Werby
    Website
    four steps forward and four steps back should put the machine back at the same position regardless of how far each step is.
    but basically I cross multiplied distance and steps. I know there is a button for it in settings but I dont get to cross multiply much in daily cnc operation so I enjoy it when I can.
    Apr 2004
    5737
    If the distance back and forth is the same, then you're not losing steps when jogging. I don't know what you cross-multiplied, but if it's not accurate, reduce the steps per unit until it is.
    Andrew Werby
    Website
    no like the motor is a turn and a half off regardless of steps.
    - - - Updated - - -
    It is losing steps in one direction only.
    Aug 2009
    1573
    ...aka preferred parking? open loop
  1. Z axis is going crazy! "Mach Blue screenset"
    By Claytonc in forum Uncategorised WoodWorking Machines
    Last Post: 01-27-2021, 09:33 AM
  2. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  3. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. VMC 800 "Z" growing
    By Lesmark in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2010, 01:26 AM
