586,721 active members*
3,192 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1994 VF3 X AXIS Z CH MISSING error when cold
    Aug 2004
    421
    I am getting this error only when the machine is first started up. I keep rehoming until it completes with no error then I run rapid at 50% for a few minutes. After this I can run at 100% for hours (28 hours this weekend) without issue. This doesn't sound like a cable problem. I do turn my heat off at night so it is sometimes in the low 50's in the morning.
    Thanks!
    If you try to make everything idiot proof, someone will just breed a better idiot!
    Aug 2015
    9
    Re: 1994 VF3 X AXIS Z CH MISSING error when cold
    Your encoder starst dying :-) You can buy new one for 350$
    Mar 2010
    1852
    Try cleaning the cable connections.
    Sep 2013
    326
    REset all the cables and connections. All the way to the rear cab.
    Here are some options for new encoders. Sub's houses are out there. I pulled a few recently. Contact them w/ your RENCO pn. they'll replace. under $200
    We have pulled ours down to glass if you do want to try and clean but I do not recommend it.
    RENCO OEM (no longer avail) RHS21D-P1-2000-8mm-5-CS-LD-M1 P/N: 78994-008
    Replace w/ (We did not need.. Just providing list from Vendors I contacted who noted Renco subs).
    Dynapar part number HC202000/0024C Spec: https://ecatalog.dynapar.com/downloa...02918-0001.pdf
    Accu-coder : EPC PN: 260-N-B-14-H-2000-R-HV-1-S-SF-4-N (S – Denotes a special connector feature). This is a connector on a shortened cable. EPC is an 18” flying lead with no connector. (*put your own connector on.)
    Data Sheet Link: 260 Data Sheet (https://www.encoder.com/hubfs/produc....pdf?hsLang=en)
    Quantum Devices: QR145-05/05-2000-0-01-T5-01-00 Qty. 1- 194.12 ea.
  1. axis enable missing / DB35 DBX2.1 is missing
    By Max2000 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-13-2019, 06:54 AM
  2. Replies: 2
    Last Post: 01-12-2018, 05:24 AM
  3. Y-Axis drift, Error 150 (Motif) 1994 VF-2 Brushed
    By ralph@nes in forum Haas Mills
    Last Post: 05-03-2014, 04:03 AM
  4. 1994 bridgeport 760-22 start up error
    By 1994Bridgeport in forum Bridgeport / Hardinge Mills
    Last Post: 05-05-2012, 01:44 PM
  5. 1994 haas vf2 error codes 161 139 103
    By duckslayer in forum Haas Mills
    Last Post: 02-21-2012, 03:17 PM
