586,345 active members*
3,254 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Thread milling code generator on excel
Results 1 to 6 of 6
    Aug 2011
    419
    Hi
    Let's develope this program.
    Attached Files Attached Files
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    Re: Thread milling code generator on excel
    hy kurmay i lookeda bit over it; you could make it run directly on the machine osp, use a macro to perform all those math in background ( this will make the excel file look more clear ) and output the program to MD1
    also, i did not had time to look into this, but is possible not only to load the file to MD1, but to auto-select it / kindly
    ps : i'll send you a sample in a few minutes
    Jun 2015
    4154
    enjoy attached
    Code:
    [ nesting tree ]
      Workbook_Open
        MsgBox
      Workbook_SheetChange
        c4_or_c5_changed
          h4change
        IsNumeric
        WorksheetFunction.IsNumber
        test
          ReDim
          addtext
            indentation
          s2s2file
        just_wait
    Aug 2011
    419
    Thank you very much deadlykitten.
    be patient, is under development
    Great solution! Thanks for this opportunity!
    The Internet has made it easy for individuals and businesses to design custom software products by https://mlsdev.com/services/custom-software-development. Most software companies allow their clients to upload their concept and allow the developers to create a working prototype. From there, the client can review the prototype and give feedback. If the product is approved, the product will then undergo several design reviews. Depending on the complexity of the design, the final product may go through several revisions before being released into the public.
  1. V27 Thread Milling Help - No Z code posting
    By hawkeyeammo in forum BobCad-Cam
    Last Post: 03-07-2015, 12:11 AM
  2. mach3 and the g code version of excel
    By woodman08 in forum Mach Mill
    Last Post: 02-07-2013, 10:50 PM
  3. Replies: 3
    Last Post: 02-18-2010, 02:58 PM
  4. CNC Code Generator for end milling
    By vijaychd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-18-2006, 07:17 PM
  5. Any Way to Improve Processing G Code with Excel?
    By keithorr in forum G-Code Programing
    Last Post: 06-21-2005, 08:29 AM
