586,121 active members*
3,643 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > XYZ Gantry Routers > How to clear corrupt file from a2mc job folder
    Jan 2021
    We have an AXYZ 5010 machine at work and today I sent a file beginning with a period (".").
    Apparently this is a big no-no as what resulted was the following:
    File manager would shut down anytime a file was moved from the computer to the machine's job folder (without the file being added).
    The corrupt file starting with the period would be in the job folder on the a2mc controller but not in file manager, thus being unable to be deleted.
    If you try to run the corrupt file it would give a bad directory message (e776)
    After speaking with a co-worker, they had mentioned this has happened once before but can't remember what was done to erase the corrupt file, only remembering that it was a quick and easy fix.
    We all know AXYZ is useless and won't move a finger unless large amounts of money is involved.
    Would anyone here have experience with this?
    Thank you in advance for any responses.
    Dec 2003
    1228
    Re: How to clear corrupt file from a2mc job folder
    I have used the older Toolpath software in such an instance.It was necessary to go into the Status tab and seek it out and then delete it.In AMC mode I haven't experienced the problem.What version of Windows are you using?
    Jan 2021
    Quote Originally Posted by routalot View Post
    Results are the same using windows 7 pro on two computers and one computer is a mac running parallels.
    Dec 2003
    1228
    Is the AXYZ machine networked?If so, can you access the folder over the network and just delete it or modify the file name?
  1. A2MC controller file read from USB
    By richard75 in forum XYZ Gantry Routers
    Last Post: 03-16-2018, 03:38 AM
  2. BXX.exe file corrupt Bridgeport Torqcut
    By marquito in forum Bridgeport / Hardinge Mills
    Last Post: 04-15-2016, 11:56 PM
  3. Lost or corrupt file
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 01-29-2012, 06:32 PM
  4. Mastercam X corrupt file
    By tstrajt in forum Mastercam
    Last Post: 09-04-2008, 10:41 AM
