586,110 active members*
3,249 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Spinde drive units and circuit boards
    Feb 2015
    82
    I am looking at another SDU for my old LB15. The units as a whole, have exactly the same part number (A06B-6044-H018) but when I look at the front circuit board, they have different numbers. Mine A20B-0009-0532, the other A20B-1000-0692. What does this mean...is one new / older than the other and will they interchange ok? Thanks
    Mar 2009
    1982
    Re: Spinde drive units and circuit boards
    It is japanese standard of standard since very beginning of industry standard in Japan ( at the start of weapon production in Japan at 19th age ).
    The same part number could be assigned to different units. Speaking about Okuma you need to provide machine and OSP serial number to get the order of spare parts correctly.
    Speaking about SDU, the part number can differ despite the module is exactly the same :-) . Maybe the unit is modified. Must be interchangeable.
    Feb 2015
    82
    Quote Originally Posted by Algirdas View Post
    Thank you. I will find out tomorrow if it works
  1. CNC for Printed Circuit Boards
    By DaveDoesIT in forum Benchtop Machines
    Last Post: 03-14-2017, 08:52 AM
  2. What CNC for engraving alu, circuit boards etc.
    By Tristano in forum Want To Buy...Need help!
    Last Post: 02-11-2017, 10:12 AM
  3. clean circuit boards/pcb's
    By adee1066 in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2012, 01:29 AM
