586,269 active members*
3,506 visitors online*
Results 1 to 3 of 3
    Jun 2006
    SPINDLE & WATER PUMP SETUP
    This is my first time posting on any forum, I hope I am in the right forum. My first question is, can I use a water pump that I bought on ebay that is marked only as 220V 50Hz, use in the US with 60Hz? I have a Huanyang VFD for a 2.2 KW spindle, should the parameter PD176 (Inverter Freq.Standard) be set to 1, which is for 60Hz? I turned it on already and it spins the spindle OK but the number set from the factory was at 0, which is for 50Hz. Thank you for any answers for my questions, I am going to have many more.
    Dec 2003
    24221
    Re: SPINDLE & WATER PUMP SETUP
    There should be no problem running the pump on 60Hz, it will run a little faster and slightly cooler.
    Also in N.A. the standard is 240vac.
    Also there is way of turning the pump on via one of the VFD outputs, and setting it for VFD-in-run, then the pump will turn on automatically with the spindle, you can also fit a OFF overide if you wish to turn it off at any time.
    Al.
    Albert E.
    Dec 2003
    24221
    I had to refresh my memory, PD176 0 = 50Hz, 1= 60Hz.
    Al.
    Albert E.
  1. water pump for HY02d223b VFD for 2,2 kw Spindle
    By ggeh in forum Spindles / VFD
    Last Post: 04-02-2020, 03:25 PM
  2. 120v water pump for 2.2kw 220v spindle?
    By kskiff7034 in forum Spindles / VFD
    Last Post: 05-11-2019, 05:29 PM
  3. Water pump using for watercooling spindle cnc router
    By allencncrouter in forum Videos
    Last Post: 01-02-2019, 01:48 AM
  4. Pump/tubing for water cooled spindle
    By Peleacios in forum Spindles / VFD
    Last Post: 01-20-2018, 04:41 PM
  5. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
