586,105 active members*
3,357 visitors online*
    Feb 2020
    4
    GRBL post-processor for plasma
    Hi, I'm just getting my feet wet with Fusion 360 and GRBL as I build my CNC plasma table.
    I drew up a simple shape and did the CAM work in Fusion360. I picked the stock plasma cutter in Fusion360 and the simulation worked fine.
    When I went to post process the CAM into the GRBL laser cutter/plasma cutter post processor, I got an error saying "The CNC doesn't support the required tool/process. Only laser cutting is supported"
    I switched the tool to the laser cutter, re-checked everything and it posts just fine.
    I checked the Autodesk CAM updates and it's the most current version of the GRBL post processor.
    I'm a bit stumped about what's wrong.
    I hope that I can get a bit of guidance here...
    Feb 2020
    4
    Re: GRBL post-processor for plasma
    I solved the problem.
    There were setup conflicts.
    Quote Originally Posted by DavidR8 View Post
    Hi. What was the setup issue? I have the same problem..
    Feb 2020
    4
    Quote Originally Posted by hypermagic View Post
    I honestly wish I could remember what I did. Sorry!
    Aug 2007
    Hi All
    Has anyone managed to get the GRBL post processor working in Inventor Cam. I am getting the same error as above "Error: The CNC does not support the required tool/process. Only laser cutting is supported." but in the Autodesk Library it states that the post processor does "Waterjet / Laser / Plasma". I have tried lots of different setting but cant get it to work. Any help would be appreciated.
    Thanks Justin
  1. SolidCam for SW Post Processor GRBL
    By lestrahl in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-08-2020, 08:19 AM
  2. GRBL post processor
    By thehomefoundry in forum SprutCAM
    Last Post: 06-05-2020, 05:43 PM
  3. GRBL Post Processor
    By error0xc00000e in forum PowerMILL
    Last Post: 05-08-2020, 08:18 PM
  4. Post processor for grbl
    By kermit582 in forum SheetCam
    Last Post: 09-30-2017, 01:40 PM
  5. Post processor for Grbl?
    By mjnewsum in forum Surfcam
    Last Post: 08-03-2017, 07:41 PM
