586,265 active members*
3,699 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 100mm to 80mm Reducer Sleeve? Swap 3kw for 2.2kw spindle
    Hi all. Please forgive me for this silly question as I've searched with no luck. Where can I get a simple sleeve to fit an 80mm 2.2kw spindle where my current 100mm 3kw spindle is mounted? Surely they make a simple sleeve for this right? I'd rather not change the mount. Thanks!
    Oct 2019
    8
    Re: 100mm to 80mm Reducer Sleeve? Swap 3kw for 2.2kw spindle
    Have one 3D printed. If you can't find anyone around you to do it, hit me up and I'll get you one.
    Sent from my SM-G975U using Tapatalk
    15362
    Quote Originally Posted by truthfriend7 View Post
    Probably not, the mounts they sell would be about the same cost, a machine shop could make you one, most likely though if you get the 80mm spindle mount the mounting holes then would be different also
    So what can you do, if you can do a new set of mounting holes then just get the mount for the 80mm spindle
    Do you have a photo of the one you have you may find and 80mm one that can use the same mounting holes
    Mactec54
    Quote Originally Posted by Shesby View Post
    I'll send you a PM once I figure out how. Thanks.Im surprised there isn't something out there already.
    For some reason it won't let me send you a PM. But I'd like to get a quote if you could PM me or email sethssticks which is located @gmail.com. thanks
    Sent from my Redmi Note 8 Pro using Tapatalk
  1. Replies: 0
    Last Post: 03-06-2018, 08:41 PM
  2. Looking for US source 3kw spindle | ER20 | 100mm dia
    By Sockles in forum Spindles / VFD
    Last Post: 07-13-2017, 06:37 PM
  3. 100mm spindle mount
    By R0bc in forum For Sale Only
    Last Post: 06-27-2017, 03:35 PM
  4. Hyundai HiT-18S Spindle Sleeve
    By CaseyCAM in forum Hyundai Kia
    Last Post: 09-21-2011, 04:43 PM
  5. Spindle motor swap, or servo swap?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 10-09-2007, 06:54 AM
