587,067 active members*
3,685 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > One thing I don't understand about the error pin.
    Nov 2015
    260
    I have the error pin Enabled. It is inverted. And "on E-Stop" is Enabled.
    The ALM output of the motor driver is a NO (Normally Open)
    If the driver goes into alarm, it works as it should. The E-Stop is triggered. The motors stop and the ES LED in the GUI lights up.
    But the ER LED does not light up. Regardless of whether the engine is in alarm or not.
    Feb 2017
    34
    Re: One thing I don't understand about the error pin.
    Hello!
    What is ER led?
    How is everything connected? without a diagram, it's hard for me to understand
    Mar 2017
    1328
    ER led shows state of error pin.
    Do you have drivers connected to error pin?
  1. low following error not a good thing?
    By Sparky_NY in forum Fagor Automation
    Last Post: 11-30-2016, 07:04 PM
  2. Help me understand
    By chezrad in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-22-2007, 02:26 AM
  3. I don't Understand
    By automizer in forum Phase Converters
    Last Post: 01-02-2006, 06:43 AM
  4. Cad/Cam Example - Help Me Understand
    By bill south in forum Uncategorised CAM Discussion
    Last Post: 06-29-2005, 08:47 PM
