586,062 active members*
4,683 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Slot cutter - chatter issues
    Sep 2015
    17
    We are running a 1.970” diameter, 12 flute solid carbide cutter mounted to a 1” HSS shank. The cutter is .236” wide with .094” radius on both corners.
    We are cutting a slot that finished at .406” wide with a 1” radius.
    The material is 4340.
    We are having trouble eliminating chatter. We are climb milling on a WFL Mill turn. We’ve tried .01” radial DOC for finish pass, we’ve tried .005” radial DOC for finish pass. A spring/free pass seems to help. HSK100 tool holder, the part setup is relatively rigid. The finish looks great on the exit of the tool path but chatter on the entry. It’s cutting a straight line to an arc to a straight line.
    Do you think conventional tool path would help?
    I don’t have much experience with a tool of this type. What SFM would you recommend? Chip load? I believe a lot of teeth are engaged in the cut at any given time. How is this determined/calculated?
    Thanks in advance for the support.
    - Branden
    Jul 2018
    31
    Re: Slot cutter - chatter issues
    Can you please provide links or pics of the cutter. That would help.
    Regards
  1. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  2. Plunging chatter and other Z-axis issues
    By cnczoner in forum Benchtop Machines
    Last Post: 02-03-2009, 03:42 PM
  3. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  4. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-16-2008, 02:06 AM
  5. Chatter vibration issues
    By Designsync in forum DIY CNC Router Table Machines
    Last Post: 02-15-2008, 12:10 PM
