586,036 active members*
3,913 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Upgrade to Through Spindle Coolant (Hyundai VX400)
    Hello
    Has anyone tried to retrofit / install through spindle coolant on a CNC mill? More specific on a Hyundai VX400 vertical machining center?
    Apr 2009
    1262
    Re: Upgrade to Through Spindle Coolant (Hyundai VX400)
    I have not tried to do it. There are typically a lot of things to change so it is done at the factory not in the field. The pull stud style, the gripper for the pull stud, the center shaft needs to be hollow, a rotary union and hoses, seals need to be added just to name a few. This is not for the faint of heart. I have heard of an "adapter style" through coolant that has a special toolholder that engages with a ring around the spindle that introduces thru coolant to the toolholder. It may be easier to add and still accomplish what you want.
    Now if your machine is "prepped" for thru coolant, then it is another matter. Add the pump and plumb it and the rest should be there.
    Best regards,
    Experience is what you get just after you needed it.
  1. Hyundai-Kia VX400 Auto power off
    By BrendanS in forum Hyundai Kia
    Last Post: 12-07-2012, 11:31 AM
  2. Coolant Upgrade???
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 10-27-2011, 04:00 AM
  3. Hyundai/KIA VX400-500 vs Hass VF2
    By CAN MACHINE in forum Hyundai Kia
    Last Post: 08-19-2010, 10:01 PM
  4. Hyundai VX400, Fanuc Oi-MC, Help Graphing
    By sthom in forum Hyundai Kia
    Last Post: 05-20-2010, 01:52 PM
  5. coolant not working after upgrade
    By mark c in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2006, 01:48 AM
