586,071 active members*
4,360 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma osp 7000l turret
    Nov 2012
    6
    Greetengs
    I would like to slow down turret revolving speed on LB 25m okuma with osp7000l
    But i do not know exact parameters
    And also i noticed that parameters for turret angle are like in this photo
    Mar 2009
    1982
    Re: Okuma osp 7000l turret
    My advice don't touch these parameters. These are automatically done with special procedure of turret alignment. You can correct manually the parameters slightly, taking care about secure clamp position.
    So, leave these parameters in piece.
    As for turret indexing speed. I don't understand a reason. Everyone wants the turret to be indexed as fast as possible normally. No?
    Check if your turret is not moving ( by angle ) when clamping and unclamping. The angle movement during clamp or/ and unclamp indicates the indexing needs update. And probably the turret must be re-alligned also.
    Jun 2015
    4154
    hy chispas i don't know for your machine, but on newer models, you should go at "machine user parameter ( turret door ) \ turret index override a-side"; it's value can be set between 0 - 100%, default 0; pls be aware that 0 and 100 % will both trigger the maximum speed, and 1 will trigger the minimum speed
    if you have shocks during turret indexing:
    ... lowering the indexing speed will reduce them, but you may find out that you may need to reduce the speed too much, in order to smooth the indexing motion; on newer models, inside "system parameters page", is an option that deals with heavy tools, that can eliminate (or drastically reduce) shocks without a big loss in indexing speed, by changing index motion cinematic
    ... try balancing your turret, by mounting your toolholders in a cross pattern, opposing equal masses
    ... you may get rid of them by reversing the indexing direction; for example, if you hear the turret always 'bumping' when indexing from 4 to 8, then try to index the long way arround; on newer models this trick requires to disable the shortest path during indexing ( from "machine user parameter ( turret door ) \ turret short path control a-side" ), and, as a result, the turret will always index in the same direction, at least in manual mode; in automatic mode, thus when runing a program, direction can be set by using M86 and/or M87
    all above parameters work, but i don't know if they are available for your machine; sorry
    however, before going hunting, check how your turret behaves when it is empty : thus strip it ( + like mr bunny says, it should be aligned, or at least not to heavy missaligned), then index it post by post, then again, in reverse :
    ... if all is ok, then perhaps the toolholders need to be re-aranged, etc
    ... if something is fishy :
    ...... like big time, then call the service
    ...... like manageable, then you may smooth out the movement by editing the parameters from the image that you shared; take a photo ( for backup reason ), then, if you dare, go with ±0.005max increments, but don't offset too much, because it may damage the internal mechanism; even on an empty turret, the indexing shock strength depends on the indexing sense, thus, if you edit those parameters to almost smooth out indexing motion in one direction, you must check also the reverse direction, and find the balance; a bit tricky, but not impossible
    perhaps you know, but please remember that an empty turret will always index waaaaaay smoother than a heavy loaded turret
    but, hmm, what are we doing here ?! kindly
    Aug 2011
    419
    Quote Originally Posted by Chispas View Post
    Greetengs
    Hi
    Open SYSTEM PARAMETER page and change to find turret parameter page with PageUp/PageDown key
    Rapid feed is active when program is running
    Jog feed is active when press turret rotation key
    "Imagination is more important than knowledge."
  1. Okuma LU-35 OSP 7000L IGF
    By gmilosevic in forum Okuma
    Last Post: 09-02-2019, 12:08 PM
  2. OKUMA OSP 7000L
    By graham1964ferreira in forum Okuma
    Last Post: 01-15-2019, 01:26 PM
  3. Okuma LT10 OSP 7000L
    By cmp79 in forum Okuma
    Last Post: 02-15-2016, 09:59 AM
  4. Replies: 4
    Last Post: 10-05-2014, 04:14 PM
  5. Okuma OSP 7000L ALARM 352
    By bobancurug in forum Okuma
    Last Post: 08-25-2011, 12:04 AM
