586,062 active members*
4,884 visitors online*
Results 1 to 1 of 1
    Jan 2021
    tos fng 63 cnc
    I purchage a used tos FNG 63 cnc milling machinewith Heidehain Tnc360 controller . All the machien parameters
    Mp are set default to 0.I m chaning some parameters manually but after power suthdown all this data is not saved.Bateries in th plc are charged. seems that machine needs program download. Due that i didnt find a back up file to downaload
    is there somebody guide me how i can start up this machine?
    Thank you in advance,
    Re: tos fng 63 cnc
    hi teokar,
    check the battery holder connections i have had the same issue a few times and had to replace the battery holder. cant help with machine parameter unfortunately.
