586,042 active members*
3,783 visitors online*
    Apr 2004
    326
    Why no homing offset for squaring?
    So, I was squaring my machine today (Avid CNC) and when I got to with .003" I realized that it would sure be a LOT easier if that last small bit could be done using an additional offset from the switch when it's reached. But after researching, I see that there is no way to do it, and in fact that is the often mis-interpreted understanding of the "Home Offs." value in the homing configs.
    It would certainly be easier to get there and then take the remaining value (measured with a feeler gauge and a square), just type in ".003" into the field, for the slaved axis. And then it would simply move the axis that small amount when backing off the home sensor.
    So why is this not possible? What am I missing?
    Re: Why no homing offset for squaring?
    Probably because the author of Mach3 never got around to it before he stopped working on Mach3 7 or 8 years ago.
    UCCNC has this feature.
    Apr 2004
    326
    :-) Sounds like some of my software....
    Thanks, maybe I should look at UCCNC.
    Apr 2004
    326
    Looks like Mach4 does have this though (good, since that was my next upgrade).
    https://support.machmotion.com/books...gantry---mach4
    May 2015
    686
    Quote Originally Posted by Kosh View Post
    As does Linuxcnc.
    Rod Webster
    www.vehiclemods.net.au
  1. Mach3 homing slave axis not squaring up
    By vdc-fx in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2020, 10:51 PM
  2. Dual Drive Homing and Squaring Script.
    By Greg_Gurden in forum Machines running Mach Software
    Last Post: 05-16-2020, 03:10 PM
  3. Homing Script Gantry Squaring
    By ineffable77 in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2019, 05:50 PM
  4. Homing position offset after power cycle (happen randomly)
    By Gerub in forum Servo Motors / Drives
    Last Post: 01-04-2017, 10:53 AM
