586,058 active members*
3,967 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Want to add proxy switches for travel limit
    Dec 2017
    12
    Looking at the option of adding Omron TL-Q5MC1 proximity switches for travel limit rather than simple snap contact switch, but am unsure if a PNP switch will work with the board. I am using a NOVUSUN NVCM6V2.1 Bought on Amazon. Will a PNP sensor work with this board?
    24221
    Re: Want to add proxy switches for travel limit
    Like many of these Chinese units, the documentation is lousy!
    I could not find out if they were sink or source inputs, it just says 'Programmable'??
    Al.
    Albert E.
    Dec 2012
    199
    Have a look at your current snap contact switches. If they connect the input to negative or zero, then I would use NPN. If they connect the input to a positive voltage I would use PNP.
    NPN makes a connection to the Negative wire of the sensor.. PNP makes a connection to the positive wire of the sensor.
    Dec 2017
    12
    Quote Originally Posted by Toinvd View Post
    Thanks, as it turns out, the board does use the negative side. Your response cleared it up for me.
  1. Slow with proximity switches, stop with limit switches?
    By rdibley in forum DIY CNC Router Table Machines
    Last Post: 12-03-2020, 04:12 PM
  2. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  3. Mechanical Vs. Inductance Limit & Proxy switches
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 03-07-2012, 04:21 AM
  4. are travel stops required? or are limit switches enough
    By multiplex in forum DIY CNC Router Table Machines
    Last Post: 12-15-2007, 05:11 AM
  5. How close to the end of your travel do you have your limit switches?
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 10-28-2005, 01:47 AM
