586,108 active members*
3,287 visitors online*
    Battery EZ6DVTT14C
    I need this battery for the AC servo driver. When I search this battery, all I can find is a battery that is called "EZ6DVTT14A" INSTEAD OF 14C at the end. Is this compatible, is there any differences? I know it's a 3.8 Li-ion AA size battery with wiring attached to the terminals that plugs into the servo driver.
    Feb 2013
    788
    Re: Battery EZ6DVTT14C
    As stated:
    The battery is purchased through your local Doosan Dealer
    Get the DVSD, DVSC, etc...model of drive, or at least the machine's serial number and call their parts department.
    They'll get you the correct part.
    Do you need the number for your local dealer?
    ...or are you just looking to purchase it elsewhere to try to save money... (that is fine, I just don't want to keep bothering you if that is your wish)
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  1. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-22-2021, 07:35 AM
  2. Best quality lithium carbonate battery grade supplier and battery grade dealer
    By elitechbio in forum Uncategorised CAM Discussion
    Last Post: 12-12-2018, 09:12 AM
  3. VF-4 battery
    By ktmflyer in forum Haas Mills
    Last Post: 08-18-2015, 04:01 AM
  4. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  5. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
