586,061 active members*
4,413 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Rotary axis parameter...need help changing
    Jan 2007
    76
    Hi all,
    I'm new to the industrial machines. Halfway understand the hobby side of cnc machines.
    I have Fagor controlled cnc router, 8055i control. The B or rotary axis somehow shifted about 3 degrees. I went into the B axis parameter and changed parameter 47, refshift, which is what the manual said, but it did not do anything? Its like the machine did not recognize the new value. I think I am missing something like how does the Fagor control recognize changes to the parameter.
    I shut the machine down, and restarted it, my change was still there, but I could not get the rotary axis to recognize the new value.
    Jul 2014
    20
    Quote Originally Posted by woodturn View Post
    Hi all,
    If you have an absolute axis, the parameter you should change should be ABSOF, or PP177 or pp178.... that all depends on the connection or type of encoder you have in you system.
  1. Changing the parameter A100 Indramat
    By indramat123 in forum Servo Motors / Drives
    Last Post: 08-01-2017, 11:18 PM
  2. Meldas L1 parameter changing
    By tomasz987 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2016, 01:40 PM
  3. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  4. Replies: 2
    Last Post: 10-17-2012, 11:22 PM
  5. ITNC530 – parameter for manual tool changing point
    By Grieche47 in forum HEIDENHAIN -> TNC
    Last Post: 11-07-2009, 05:59 PM
