586,114 active members*
3,391 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Incorporating Switch into CNC Code
    Sep 2015
    19
    Does anyone know if it is possible to incorporate a switch into CNC Program. Basically I want to run the X axis towards a part until a switch is made. When switch is made the x axis will stop and the program will advance to the next line of code and the Y axis will kick in. Sort of like how probing works. I know it can be hard wired without cnc control using arduino, but wondering if there was any way to do this in Mach 3? Thanks in advance.
    Dec 2013
    5717
    Re: Incorporating Switch into CNC Code
    Maybe use M1 (optional stop) or M0 (program pause), then wait for the input to trigger before proceeding.
    Not sure if this will work in Mach3, but worth looking at.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    4376
    Mach3 and Mach4Hobby DO NOT have conditional Gcode whereas Mach4Industrial does.
    With conditional Gcode, sometimes called Fanuc B, you can have a statement like:
    If (signal/switch/condition) then
    else
    endif
    As Jim points out you may be able to use a trick to accomplish what you want in Mach3, there was a guy BR548, a regular on the Mach3 forum, and he was
    famous for these little tricks to get Mach3 behave as if it had conditional programming. Could be worth posting there...
    Craig
  1. Replies: 4
    Last Post: 07-31-2019, 09:54 PM
  2. Replies: 0
    Last Post: 03-23-2016, 03:02 PM
  3. Incorporating a pallet change into a program
    By cdmnyew in forum G-Code Programing
    Last Post: 09-29-2015, 12:43 PM
  4. Thread count considerations when incorporating a fastener into a design
    By jerseyguy1996 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-29-2014, 03:04 PM
  5. Z axis limit switch mounting (and X and Y switches and G-code too)
    By momus_cnc in forum Momus Design CNC plans
    Last Post: 10-03-2011, 04:14 AM
