586,108 active members*
3,135 visitors online*
    Sep 2019
    4
    XSY-AT1 CONNECTION TRANSLATION
    Hi All
    Please excuse my lack of knowledge.
    Can anyone help me? I am trying to connect my XSY-AT1 to a Gecko G540 using a relay to control the motor with MACH3.
    My problem is trying to work out the correct connections on the VFD.
    See attached photo. I wish to connect the outputs from the relay to For and DCM which are not labelled on the XSY-AT1. It looks like I should use X4, can someone verify if I have this correct.
    Thanks in advance.
    Greg
    Dec 2012
    199
    Re: XSY-AT1 CONNECTION TRANSLATION
    They are not labelled because you can program the X inputs for different functions.
    By default X4 input is for start / stop. with parameter 53 you can set it for other functions.
    So in your case, a relay between ground and X4 input should be able to start and stop the motor connected to the VFD
    Here you can find the manual
    http://myosuploads3.banggood.com/pro...9SKU792664.pdf
