586,389 active members*
3,204 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Trying to build my own CNC Laser cutter
    Feb 2021
    12
    Hi everyone,
    I'm currently designing my own laser cutter, for hobby purposes. I already have the design of the CNC made, but I have some questions about the laser cutting part. I thought about using the CO2 Laser tube, but I do like how the laser module is more compact and requires a lot less parts to operate it (no coolant reservoir, no reflectors needed, etc). I don't have as much experience with the laser module tho, so what do I need to be mindful of should I use it? Also, how powerful would I need to cut, say, brass or copper sheets up to 2mm thick?
    Thanks in advance.
    Nov 2008
    643
    Re: Trying to build my own CNC Laser cutter
    CO2 lasers can not cut metals. Only organic materials and plastics. Things that will burn or melt.
    I’d recommend doing more research before you set on a direction.
    Feb 2013
    51
    That's not accurate. CO2 lasers can cut metal but they don't do as well as fiber and the operational cost is more.
    I have a friend that has one of these but is a 150 watt and he cuts 18 gauge everyday. It also has a weak side further away from the laser tube so that side usually doesn't cut as well.
    https://www.youtube.com/watch?v=N7GECxIOJS0
    Yongli 300w +auto focus laser head ,can process less 1.5mm thickness stainless steel cut work ,but this type machine main work is still process non metal .acylic ,thin MDF board .
    1326 metal non metal laser cutting machine cutting steel
    https://youtu.be/kSRApr5VpcA
    https://youtu.be/sqvdwKih-9E
    https://youtu.be/AP2gCZycKJc
  1. New Machine Build High Precision Fiber Laser Cutter
    By mshamber in forum Fiber Laser Cutting Topics
    Last Post: 08-31-2018, 01:02 PM
  2. Newbie making 2x3 meters laser cutter/engraver. Build log + questions
    By Rokas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-14-2014, 01:40 PM
  3. Diy Laser cutter build - X axis direct drive?
    By gavztheouch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2012, 08:44 PM
  4. Laser cutter build
    By breaksbb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-15-2009, 10:12 AM
