586,096 active members*
3,779 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Own "Start On Line" button do not work
Results 1 to 7 of 7
    Nov 2015
    260
    I noticed that a button of its own has not been displayed for a long time.
    At first I thought that I had forgotten it when I transferred it to the new computer.
    Now I've checked and found that the code:
    Code:
     "cmd: "Machine.Advanced.Start_From_Selected_Line" image="ownicons/SL.svg" imagechange="True"
    is present in the file. But the button is not shown in the GUI.
    It works on the old computer with an older TNG v2 version.
    Mar 2017
    1312
    Re: Own "Start On Line" button do not work
    Correct name is "Machine.Start_Option.Start_From_Selected_Line "
    (test09.py returns list of all implemented commands)
    Aug 2020
    131
    any special reason why its missing the s from Start_Options ?
    where can the test09.py file be found?
    Mar 2017
    1312
    test09.py is part of API, available here:
    https://planet-cnc.com/wp-content/uploads/sw/PlanetCNC_API.zip
    Nov 2015
    260
    And with which app should I start this file?
    Code:
    Traceback (most recent call last):
      File "/Users/admin/Downloads/API 2/Python/test09.py", line 5, in <module>
        import tng
    ImportError: No module named tng
    Nov 2015
    260
    I am currently looking for the correct syntax for the following button
    Code:
    cmd: "Machine.Motors,_Limits,_Probe.Motors_Enable" image="ownicons/MLP.svg" updown="_mybutton == 1" updatefast="true" imagechange="True"
    Code:
    cmd: "Machine.Motors,_Limits,_Probe.Soft_Limits_Enable" image="ownicons/MLP.svg" updown="_mybutton == 1" updatefast="true" imagechange="True"
    Code:
    cmd: "Machine.Motors,_Limits,_Probe.Hard_Limits_Enable" image="ownicons/MLP.svg" updown="_mybutton == 1" updatefast="true" imagechange="True"
    Aug 2020
    131
    should be
    Machine.Motors.Motors_Enable
    Machine.Limits.Soft_Limits_Enable
    Machine.Limits.Hard_Limits_Enable
    according to output from test09.py
    to run test09.py you need to have python installed on your pc. And you need to extract the complete archive and not only the test9.py
    In addition I needed to change line 8 in tng.py to point to the full path of PlanetCNCLib64.dll
    I changed it from
    dll_name = "PlanetCNCLib64.dll"
    to
    dll_name = "C:/PlanetCNC/PlanetCNCLib64.dll"
    where C:/PlanetCNC/ is my installation path of PlanetCNC
    Somehow my python installation did not correctly include the path variable (Gave it a try with dll_path and the system path variable first with no success)
    Output from test9.py is attached to this post for convenience.
  1. Problem with "Start from Selected Line"
    By tantemay in forum PlanetCNC
    Last Post: 08-23-2020, 07:21 PM
  2. Replies: 2
    Last Post: 10-18-2019, 12:12 PM
  3. Replies: 4
    Last Post: 02-10-2019, 10:24 AM
  4. Replies: 8
    Last Post: 11-15-2009, 01:35 PM
  5. Where is the "start from line"
    By mbinelo in forum LinuxCNC (formerly EMC2)
    Last Post: 08-13-2008, 05:11 AM
