586,437 active members*
3,979 visitors online*
    Feb 2021
    4
    Bridgeport Interact parameter list TNC310
    Hello,
    I received a Bridgeport series 2 interact 2 from our company.
    The machine has been stored for a long time, so batteries were oxidized and parameters are lost.
    The problem is that the controler has been rebuild in the past from a TNC145 to a TNC310.
    NC software number is 286149 13
    I noticed that de parameter list of a TNC410 looks simular, can I try those lists ? I don't want to cause any damage to the controler.
    Can anyone help me out.
    Grtz Tom
    1121
    Re: Bridgeport Interact parameter list TNC310
    I retrofitted similar iron with a TNC 310 I may somewhere have an old parameter list.....but....yeah....I had linear scales so, probably not useful
    read these:
    https://www.cnczone.com/forums/bridg...ml#post2181424
    and try to interpret them into the 310
    The 310 has the newer standard for parameters, IOW in every machine from the nineties on the same parameter does the same thing. The old 151 etc are not the same format
    SO you need a description of what parameters do what in a 151, and what parameters do what in a 310[or almost any late control]
    The first series of parameters are the most important, they define the working space and servo setup so that the machine will move, once you do that, it will take time but you can make the rest of it go
    1121
    https://www.cnczone.com/forums/bridg...arameters.html
    a place to start
    The 310 also has a programmable PLC, and I hope it was run from the permanent memory, because that will be a bear to reproduce
  1. Bridgeport interact 412 machine parameter
    By encapsulation in forum Bridgeport / Hardinge Mills
    Last Post: 04-05-2019, 05:34 PM
  2. Parameter list help please
    By Straightshotperformance in forum SERVICE FOR CNC-MACHINES
    Last Post: 07-22-2017, 04:48 PM
  3. Parameter list
    By Rick_B in forum Fanuc
    Last Post: 03-29-2013, 08:53 AM
  4. parameter list 3tc
    By R.thayer in forum Fanuc
    Last Post: 09-17-2011, 08:12 PM
  5. parameter list
    By Drye-123 in forum Fanuc
    Last Post: 06-17-2008, 05:56 AM
