586,612 active members*
3,462 visitors online*
Results 1 to 11 of 11
    Jan 2019
    6
    Vacuum seal gasketting
    Hello,
    Hope I can ask someone with this gasket a question.
    We bought an new industrial cnc in December, (why arent I asking them? Another issue...)
    We applied a gasket they recommended around each vaccum zone. The gasket they recommend sounds like normal on here where it sits a bit above the phenolic then compresses with the vacuum.
    Well thats all well and good, but here is our issue. When we for example want to cut from say zone 1 a piece to fit right in there. We would then turn off the other zones, well that compression somes into play and raises that side of the table and messes up my cuts.
    Anyone else have this problem, or am I extraordinarily lucky? If so whats the slution, no gasket?
    Thank in advance
    Jul 2018
    6417
    Re: Vacuum seal gasketting
    Hi Alki - How's does compression raise the table? maybe a photo to explain? or more words?? Do you mean the job is sitting on the uncompressed seals? Peter
    He's got an MDF spoilboard with a multiple zone plenum underneath it, with each zone having it's own seals/gaskets. When he turns the zones off, there's no vacuum to compress the seals in those zones.
    Nov 2012
    1267
    There should not be a gasket in any area where the vacuum is off. If you turn a zone off, either remove the gasket from that zone or keep your parts/spoilboards away from the uncompressed gasket.
    Are you using a single large MDF spoilboard that covers the entire table? In that case, you can keep the vacuum on in all zones and cover the unused portions of the spoilboard to seal the vacuum.
    Jan 2019
    6
    Hello thank for the replys,
    Correct: He's got an MDF spoilboard with a multiple zone plenum underneath it, with each zone having it's own seals/gaskets. When he turns the zones off, there's no vacuum to compress the seals in those zones.
    Jan 2019
    6
    So what do you guys do with this situation? You cant remove the gasket without taking the entire spoilboard off, I can block out areas and leave all the vacuum on, but that defeats the purpose of the vacuum areas.
    Does anyone have any recomendations on what they do in this situation?
    Jan 2019
    6
    What do you think Ger21? I was thinking to cut my mdf into the sections, but if I do that when I have a part bigger than my section Im back to bocking it out.
    Thanks again for any thoughts
    Aug 2005
    205
    Cut thin plastic sheets roughly the same size as the unused zones. Use them to cover the unused areas of spoil board. You still have to draw down those areas, but you won't waste vacuum and you won't distort the spoil board. Reject vertical grade laminate works fairly well. Or, in a pinch, construction plastic sheeting works.
    I agree with Marv, but I'd use something a little thicker than laminate, as it will usually seal better.
    One big zone and cover the unused part of the table, rather than separate zones.
    Nov 2012
    1267
    The best strategy depends on the size and variety of the parts you are making.
    One option is to make several spoilboards - one for each common stock size. At our furniture factory, we have dozens of spoilboards for each CNC machine. When we design a new part, we also design and make a dedicated spoilboard to go with it.
    Jan 2019
    6
    OK thanks all for the tips!
