Re: 95 Okuma LNC8 drilling help
Perhaps we should compile a list of what all needs changed in the post and get a good one together we can both use
hy cg if changes can be done using replace function, then all you need is to macro a text editor
if also arguments require editing, then it may still be possible
if you wish, share your list of desired changes, and maybe i can help you
it's easier to translate a post output, than configure the post itself / kindly
