586,036 active members*
3,654 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Sram card internal battery backup failure
    Jul 2020
    18
    Dear all,
    Recently I got a used Sram Card(Mitsubishi Melcard 1MB). I have to use this memory card for programs backup from Mori Seiki SL-250(Fanuc 18i-T).
    For first when I get the card I changed backup battery(3V BR2325) with a new one because the old was completely discarghe. With the new battery I install the memory into a Sram/Pcmcia card reader for PC. When I turn on the laptop Windows message says : Memory card need to be formatted, format?
    I chose not format the card because I am not sure if it is the correct way to perform that operation.
    My question is the follow:
    It is necessary to format Sram Card after internal battery backup failure for a long time?
    Re: Sram card internal battery backup failure
    Yes, but you should format it on the CNC not the PC.
    Aug 2016
    10
    SRAM cards have an external and internal rechargeable battery. If the external battery has been left dead for a long time, the internal rechargeable battery is now dead. Therefore, even if you replace the external battery, it will not work properly because the internal battery is damaged.
  1. 15MB SRAM BACKUP
    By nt48375 in forum DNC Problems and Solutions
    Last Post: 11-05-2015, 11:47 PM
  2. CF card SRAM backup/Restore issue
    By elab.ess in forum Fanuc
    Last Post: 04-21-2013, 01:38 AM
  3. Sram backup.
    By ajm100a in forum Fanuc
    Last Post: 12-18-2009, 03:12 PM
  4. New sram backup question.....
    Last Post: 04-23-2008, 09:19 PM
  5. SRAM Backup
    By msaiprasad in forum Fanuc
    Last Post: 12-06-2007, 08:04 AM
