586,410 active members*
3,188 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VH-65 troubleshooting
    Mar 2013
    88
    I posted this on PM, sorry if you hang out at both
    I recently purchased a used VH-65. It looks to be in excellent condition, with little signs of use, but the seller didn’t know if it was functioning as he had no Fadal .
    My machine previously had a 4th on it before I got it. It’s wired and had a 1010 card and amplifier.
    The amplifier and 1010 card appear to be working by the blinking lights and green light on the amp card.
    I have air hooked to the machine and the solenoid is working I believe.
    I changed my parameters per the manual and restarted the machine.
    At first I was getting a #18 position error, now I’m getting a motor overload.
    I’m guessing the brake is stuck.
    How does the brake work? Air applied appears to be on? I have 90# air to the machine , I tried running a separate air line to the 4th and cranked the air up to 125. I can’t hear anything moving inside the 4th, can you hear the brake engage normally?
    Anything I can check prior to taking the VH-65 apart?
    Thanks for the help
    Sent from my iPhone using Tapatalk Pro
    Aug 2009
    1573
    Re: VH-65 troubleshooting
    Quote Originally Posted by ripperj View Post
    Thanks for the help
    M60/M61 is the Brake Code. There is setting in SETP for Auto Brake. Normally you can not hear the Brake operation other than the Air pressure relief.
    The 1010-axis Card should be blinking Green and no red light when Axis drivers are on.
    DJ
    Mar 2013
    88
    Ok thank you
    I recall a parameter that was yes/no for the brake, I’ll have to look for the auto brake setting(unless it’s in auto if you select No to the M60/61 setting?)
    Mar 2013
    88
    Turned out to be a stuck motor brush, it had varnish or epoxy on it. Works like a champ now
  1. Troubleshooting
    By BFHammer in forum K2CNC
    Last Post: 11-26-2018, 06:42 PM
  2. PLC Troubleshooting
    By bin95 in forum Videos
    Last Post: 09-23-2016, 12:10 PM
  3. MV-35 Troubleshooting
    By leach.jared in forum Mori Seiki Mills
    Last Post: 07-08-2016, 12:06 AM
  4. Troubleshooting help
    By Twoeyes in forum DIY CNC Router Table Machines
    Last Post: 12-15-2011, 04:52 AM
  5. Troubleshooting Help
    By jdell42 in forum DIY CNC Router Table Machines
    Last Post: 10-07-2009, 05:17 PM
