586,096 active members*
3,779 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Pathpilot Lathe post for F360 inserting M0s
    Aug 2006
    51
    I noticed when I run the code from F360 on my Rapidturn, the program is forcing 2 "cycle start" actions between tool changes. Easy fix right....turn off optional stops. Didn't work so I checked out the gcode and saw M0s (non-optional stops) inserted by the post before each tool change. I double checked my parameter settings in F360 post processing dialogue to make sure I had the insertion of stops turned off (set to "no"). Anyone else seeing this and can it be corrected without changing the pp code. I can certainly do that, but don't want to have to do it every time the pp gets updated
    Aug 2006
    51
    Re: Pathpilot Lathe post for F360 inserting M0s
    I contacted Tormach and they are changing the post to do M1s rather than M0s and will send it to Autodesk.
  1. No 5/16-18 thread in drop down menu in pathpilot for lathe
    By jeffrey001 in forum Tormach PathPilot™
    Last Post: 07-18-2018, 05:22 PM
  2. Replies: 4
    Last Post: 06-11-2018, 06:25 PM
  3. F360 - Tormach PCNC 1100 Post Issue on Drilling
    By smokediver576 in forum Autodesk Post Processors
    Last Post: 08-27-2017, 11:29 PM
  4. PathPilot Lathe (1.9.4b) - Didn't prompt for tool change = CRASH!
    By brianbonedoc in forum Tormach PathPilot™
    Last Post: 06-06-2016, 08:26 PM
  5. PATHPILOT - MILL AND LATHE LOADED?
    By keen in forum Tormach PathPilot™
    Last Post: 01-09-2016, 12:37 AM
