586,096 active members*
3,397 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help with wear offsets in threadmilling operation
    Mar 2011
    146
    Trying to do some threadmilling with a oi-MC control. The code has the following:
    G41 D1
    Threadmill is moving G03.
    and of course, G40.
    I'm trying to figure out what to put in the offsets. I have both the Geometry (D) and Wear (D).
    I'm trying to control the fit of the thread and it is currently too small. I'm thinking a negative number in the wear column for that tool will cause it to cut a tad bigger. Is this correct?
    Jul 2008
    71
    Re: Help with wear offsets in threadmilling operation
    Geometry offset is usually 1/2 tool diameter, (if that's how your machine is setup). You can subtract from the Geometry, or go negative in the Wear. I put tool info in the Geometry, and adjust size in the Wear. ---- John :cheers:
    Dec 2008
    3109
    Quote Originally Posted by J S Machine View Post
    G41 D1
    and of course, G40.
    Caution with Oi control G + W offset = total offset
    For this reason you need to work out a procedure to follow always ie. T#,H#,D(#+30)
    (example T1 uses H1D31)
    Now your query, a smaller number makes the toolpath closer to your programmed contour, a neg number can be used.
    Sounds as if you program using tool centreline method, where a zero offset is used when using a correct sized tool.
  1. Fanuc 0T-A wear offsets locked
    By forhire in forum Fanuc
    Last Post: 07-26-2019, 12:01 AM
  2. External control of wear offsets
    By jwl300 in forum Fanuc
    Last Post: 12-22-2016, 10:56 AM
  3. Wear offsets okuma multus b300
    By tonepaq in forum Okuma
    Last Post: 10-27-2016, 02:40 PM
  4. Fanuc 0T-B Wear Offsets not doing anything
    By wtopace in forum Fanuc
    Last Post: 08-03-2016, 03:37 PM
  5. Fanuc 0TC and Tool Wear Offsets
    By rrbmachining in forum Fanuc
    Last Post: 07-05-2010, 04:06 PM
