586,117 active members*
3,329 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > What's wrong with this AC Servo?
Results 1 to 9 of 9
    Jan 2014
    4
    Hi all,
    So I made a cnc lathe (which I will introduce in a different thread) with a 750w Yaskawa AC servo and SGDA-08AP controller driving the spindle. After moving house, it sat unused for a few months. The other day, when setting the whole thing up again, the servo started making an awful grinding noise when turning the power on and throwing alarm A.70 (overload), even before running it. I'm scratching my head and wondering what the problem might be? A config problem, or something more serious?
    Any help will be greatly appreciated - including a brief video and pics showing the issue.
    https://youtu.be/DoyAoMtU0Kw
    Attachment 459360
    Attachment 459362
    Thanks everyone!
    Fit0
    Dec 2013
    5717
    Re: What's wrong with this AC Servo?
    It almost sounds like the gain is set to high. Maybe try auto tuning and see if that fixes it.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    4
    Thanks Jim. Will autotuning work despite the alarm going off? Sorry if that's a silly question - servos are still a bit of a mystery to me.
    Dec 2013
    5717
    You may have to do some adjusting, maybe set to factory defaults or something before autotuning. I don't know what adjustments are available in those units.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    So how would you autotune a servo a motor with factory default, that is never going to work
    They are the same to setup as any other servo drive just a lot more options / features than a lot of other servo drives others, but they don't take much to get running
    Mactec54
    Dec 2013
    5717
    Very insightful and helpful mactec54. Thank you for posting that.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    4
    Thanks so much for helping me think this through the right way guys. As it turns out, the drive had lost the settings somehow (prolonged lack of use?) so I manually reset the user parameters as per the manual - and now we're back in business! Thanks again. Time to make some chips!
    15362
    Quote Originally Posted by Fit0 View Post
    Hi all,
    Attachment 459360
    Attachment 459362
    Thanks everyone!
    Fit0
    If you had it running before the move you should check your wiring Grounding and Encoder connections
    Mactec54
    ^^^^^This... moving the machine shouldn't have affected the tuning... unless something mechanically changed. Did the drive retain the parameters you had in it? If so, check all your wiring, shielding, grounding, etc. Also, make sure your encoders, resolvers, hall effect devices, etc., are well connected. The "grinding" is oscillation.
    Sent from my SM-N975U using Tapatalk
  1. Replies: 4
    Last Post: 12-26-2023, 06:54 PM
  2. Need help brushed servo moves in wrong direction
    By FAB_Bros in forum Servo Motors / Drives
    Last Post: 08-21-2020, 03:13 AM
  3. What's wrong here?
    By CharlieM in forum G-Code Programing
    Last Post: 04-18-2010, 07:15 PM
  4. 10 IPM, am I doing something wrong?
    By jupdyke in forum Mechanical Calculations/Engineering Design
    Last Post: 09-16-2009, 04:26 PM
  5. anyone know what i am doing wrong
    By pauluk in forum Digitizing and Laser Digitizing
    Last Post: 02-16-2006, 05:48 PM
