586,058 active members*
3,586 visitors online*
Thread: fanuc motor
    Nov 2006
    30
    fanuc motor
    what would be a good alternative drive for a fanuc A06B-0754-B490 #3000
    200V 4 pole 5.5/7.5 KW 1500/6000 rpm
    Dec 2013
    5717
    Re: fanuc motor
    I'm using a Automation Direct GS3 drive on mine, but any properly rated sensorless vector VFD will run the motor. But you will lose indexing capability if you use a VFD. And I would guess that a VFD would not be compatible with the Fanuc controls. I ripped everything that said Fanuc out of my machine, with the exception of the spindle motor.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2006
    30
    Re: fanuc motor
    did the same with my machine and also would like to keep the spindle motor but need indexing for tool changer
    Dec 2013
    5717
    Re: fanuc motor
    Quote Originally Posted by HANSENTECH View Post
    If not already equipped, you could install ''shot pin'' indexing on the spindle for tool changing.
    This would be a pin that enters a slot, pushed in by a small air cylinder. Rotate at very low speed, and kill the run signal to the VFD when the pin drops into the slot.
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  2. fanuc dc motor
    By keithmech in forum Fanuc
    Last Post: 08-20-2007, 10:42 PM
  3. need FANUC motor
    By recycleroy in forum MetalWork Discussion
    Last Post: 09-22-2006, 03:54 PM
  4. Fanuc motor ???
    By jevs in forum Servo Motors / Drives
    Last Post: 03-16-2005, 11:47 PM
