586,094 active members*
3,829 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > LagunMatic vmc 3516 no return home Dynapath 40
    I start with the following problem that I am having with my lagunmatic with dynapath delta 40. We had problems with the Y axis, so we decided to change the optical rule and everything seemed to be fine, but at the time of sending the axes to their home, the Y axis generates the out-of-limit alarm, so I think I have to reconfigure my home. machine but I don't have the configuration manuals. any help would be very helpful thanks.
    Aug 2011
    121
    Re: LagunMatic vmc 3516 no return home Dynapath 40
    ZanderGahel,
    Can you reference the axes? If so, you can jog the Y axis to about a quarter inch from your travel limits and note the Y coordinates. Go to the Set Up screen and compare the Y coordinates you noted to the Y Travel Limits (THY, THY). Update the Y Travel Limits if required. This screen will also have the Home Position if you need to change this.
    RT
    Cngbrick,
    the Z, X axes do reference, but when it is finishing referencing the Y axis appears as out of limit, this happens because in one corner there are 2 limit switches 1 is home and the other is on the limit so when it is finishing referencing it crushes At this end and generates the alarm, I wanted to know if there is a way to save the home again as in the fanuc, which is parameter 1815.
    Aug 2011
    121
    You can edit the limits by entering them directly in the Set Up screen. You just enter TLY or THY and your new value.
    RT
    Jan 2009
    52
    If the axis is not referencing then try this. Jog the axis away from the reference switch. Reference that axis. Once the reference starts trip the reference switch by had (hold it on). With in about 1 revolution of the ballscrew the axis should stop.
    Reference on a Dynapath usually goes like this. - Reference axis hit the reference switch, the CNC then looks for the next Marker pulse on the encoder and stops on that mark unless an offset is added to the parameters.
    So if you run the test suggested and it stops, I would try it again just to be sure. If it does not stop then the switch or the marker pulse is most likely the cause.
    Hope this helps.
  1. Dynapath Delta 40M - Lagunmatic 3516-SX
    By giz in forum Machinery Manuals / Brochures
    Last Post: 07-29-2022, 07:07 AM
  2. Lagunmatic 310 with a dynapath issue
    By travkroberts in forum Dynapath
    Last Post: 11-12-2014, 03:07 AM
  3. need advice asap looking to buy vmc lagunmatic 3516
    By suppermaxxin in forum CNC Machining Centers
    Last Post: 02-17-2014, 05:30 AM
  4. Lagunmatic VMC 3516 1994
    By bglad in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2012, 01:40 AM
