586,096 active members*
3,687 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > SCM M100F CN1061 X axis external alarm
    Feb 2021
    Exclamation SCM M100F CN1061 X axis external alarm
    We recently got a used SCM M100F CNC. at first start up we had an error on the "X" axis servo pack (encoder back up error). I was able to clear the error using the SigmaWin software.
    But now when the reset is pushed, I have no errors. Then I push white P02 (turn system on), I get CN1061 X axis external alarm. I cant find any documentation on this error and looked through all
    the electrical diagrams, and cant find anything related to this error. I'm assuming I still need to calibrate the "X" axis, but it wont let me jog any axis. any help or documentation would be greatly appreciated.
    Jul 2018
    31
    Re: SCM M100F CN1061 X axis external alarm
    Hi, so after clearing the "encoder backup error" alarm are you sure that the X axis data has not changed ? The machine works on absolute encoder system and needs the axis position to be saved and machine should not forget the position ever. When you turn the machine off, the batteries comes into play. The batteries must be changed before end of their life so that the axis data isnt lost.
  1. External Alarm 1046
    By ErocG54 in forum Community Club House
    Last Post: 08-09-2013, 02:32 PM
  2. SuperSlant SB3-GN 2009 external alarm
    By cruizer67 in forum Hardinge Lathes
    Last Post: 06-21-2013, 07:07 PM
  3. External E-stop alarm
    By Silver_Hawx55 in forum Fanuc
    Last Post: 06-21-2011, 02:23 AM
  4. OSP 5000L-G :131 alarm-a external
    By m@chinist in forum Okuma
    Last Post: 02-11-2011, 10:04 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
