586,105 active members*
3,343 visitors online*
    stepper motor calibration
    lead screw is Tr8x8 (P2)
    Lead Screw Diameter ? :8 (mm),4(mm),2(mm)
    Pitch 2 (mm)
    Lead 8 (mm)
    4 Start
    cnc is 1500x1500 linear rails, nema 23 1.8 degrees
    I have a ball screw cnc that maker suggests 4 micro steps which on my driver is 800 setting on dip.
    when I run a 12in calibration test the machine only goes 1.5 inches. This is with the controller setting of 800
    for this machine to be accurate I have to take controller step setting to 100.
    should the controller setting be closer to the dip switch setting on driver.?
    I want 4 micro steps but dont think I am gettting with the 100 setting in controller,.
    Please tell me how to set the motor calibration best.
    thanks
    Jan 2007
    146
    Re: stepper motor calibration
    Most stepper drives settings go steps to turn the stepper motor 1.8 degrees. So I think you need a setting of 4.
    I haven't done the math, but I am wondering if you have not converted from mm to inches. At 4 pulses/step you need 800 pulses/rev (360/1.8=200) to move 8mm linearly,(about .315") to move 12" would take 38.1 Revolutions. (12/.315) to move an inch you need about 2539.68 steps (1"/.315" x 800 step/rev ).
    Nov 2012
    1267
    100 steps per millimiter is the correct number for your setup.
    The driver DIP switch setting of 800 means "800 steps per turn". The driver has no way to know what kind of a ballscrew you have, it operates in terms of steps, not millimeters or inches.
  1. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  2. Mach3 - Motor Calibration in MM's - Help !!
    By jwhitten in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2015, 05:46 AM
  3. Replies: 1
    Last Post: 05-28-2013, 04:25 AM
  4. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  5. help me in stepper calibration
    By rimawi2008 in forum Mach Mill
    Last Post: 04-22-2011, 06:34 PM
