I have a demo of mach 3 - I would like to know where to put the config file that I received with my controller card - Or is there a way to set it up.
Sorry if this is the wrong place for this question
Drakkn Custom Shop http://www.drakkncustomshop.co.uk
If it's an .xml file, just drop it in the Mach3 folder. You'll need to start Mach3 with that profile. Instructions to do that can be found in the manual.
Thanks it is an xml file - great support - very quick answer
Thanks that worked
How do you set up your machines work area in mach3
and is there a manual i can download
You can get the manual at www.machsupport.com
Here's a link to some video tutorials on the mach site:
http://www.artsoftcontrols.com/artsoft/videos.htm
Good luck,
Jack
Walking is highly over-rated
cheers - got the manual will attempt to inwardly digest - then make my z axis work - think the stepper motor is not much good.
