586,608 active members*
3,512 visitors online*
    Mar 2021
    Laser cutter for cutting self-adhesive paper
    I am looking for a laser cutter that can do the following:
    1. Cut self-adhesive paper with a precision of +/- 0,1 mm
    2. Simple to configure and use. The shapes to cut will only be cirkles and squares with sizes of max 5 cm. Typically it will be less than 1 cm
    3. The price should be as low as possible. Not advanced features are needed as the cutter only will cut simple shapes from self-adhesive paper.
    I would like to ask if anybody has experience cutting in self-adhesive paper and can recommend a laser cutter? My main worry is if the adhesive abilitites will be diminished during the cutting process because of the high heat(?)
    Nov 2015
    371
    Re: Laser cutter for cutting self-adhesive paper
    What about the aesthetic considerations? Are you going to cut adhesive stencils for masking or you need it for finished products with clean-cut edges? Volume of production?
    If you are looking for inexpensive machine for occasional use, I would suggest to look at the small size vinyl cutters.
    Mar 2021
    Clean-cut edges are needed. The volume will be between 50 and 2500 pieces.
    Here is a link to an image that is very close to what I need to cut:
    https://www.magnet-shop.com/media/im...-sk-50_2_2.jpg
    Clean-cut edges are needed. The volume will be between 50 and 2500 pieces a 1-2 times per week.
    I have thought a lot about vinyl cutters, but I am concerned that the adhesive will make the knives dull quickly. I spoke will a manufacture of vinyl cutters and they confirmed that dull knives will be a challenges in my use case. That is why I am now looking into laser cutters.
    Nov 2015
    371
    Quote Originally Posted by larsbs View Post
    Clean-cut edges are needed. The volume will be between 50 and 2500 pieces a 1-2 times per week..
    Maybe a 5-10 thousand pieces a month would justify the investment in a laser machine specialized for your application - capable of clean cuts without any burning of the edges.
    The machine would be in the 8-20K range if imported from China. And 30-50K if it is made by a western brand.
  1. Laser Cutter Machine for Paper
    By vijaypeta in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-28-2020, 02:56 AM
  2. cutting paper by laser cutter
    By Nolan Yang in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-16-2014, 04:14 AM
  3. Good Buy? Paper Craft Laser Cutter
    By 2_many_hobbies in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-29-2009, 06:01 PM
