586,042 active members*
3,870 visitors online*
Results 1 to 8 of 8
    Mar 2021
    4
    Need 20 small steel blocks with 2 counterbore holes each
    Please quote price and availability for the CNC fabrication of 20 pieces of the block with two counterbore holes shown in the attached files. The partfiles.zip contains four part files:
    MountingBlockForPlates-From1in-NoThreads.ipt
    MountingBlockForPlates-NormalDim-NoThreads.stp
    MountingBlockForPlates-NormalDim-NoThreads.ipt
    MountingBlockForPlates-From1in-NoThreads.stp
    The "MountingBlockForPlates-NormalDim-NoThreads" is the preferred version, but I included a 1x1xA version in case that will be significantly cheaper
    to make
    The .ipt and .stp alternates are for convenience, and should be equivalent.
    I am looking for +/- 0.005" tolerance or better, but the only real critical dimension is the hole spacing
    A36 steel
    Finish: nothing special
    Dave
    Aug 2010
    8
    Hello I'm interested. [email protected].
    Feb 2006
    196
    Re: Need 20 small steel blocks with 2 counterbore holes each
    Dave,
    What is your email to send the quote?
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Mar 2021
    4
    Quote Originally Posted by dpryor View Post
    Dave,
    Reply to the note I sent to your yahoo email address
    Aug 2012
    35
    Good morning Dave,
    Please send me your email to: [email protected] and I will send you a quote back this afternoon.
    Thank you,
    Lee Ort
    Elevated Manufacturing Solutions
    1-844-MFG-GURU
    Mar 2021
    4
    Quote Originally Posted by XYZ-ABC View Post
    Good morning Dave,
    Thank you,
    Lee Ort
    1-844-MFG-GURU
    The email bounced with the error below. It looks to be yahoo related. I have seen problems emailing yahoo addresses in the past.
    <[email protected]>: host
    mx-biz.mail.am0.yahoodns.net[67.195.204.83] said: 421 4.7.0 [TSS04]
    Messages from 69.89.20.237 temporarily deferred due to unexpected volume or
    user complaints - 4.16.55.1; see
    https://postmaster.verizonmedia.com/error-codes (in reply to MAIL FROM
    command)
    Aug 2012
    35
    Dave,
    Please try and send it to: [email protected]
    Thank you,
    Lee Ort
    1-844-MFG-GURU
    Mar 2021
    4
    Dave,
    Sorry, I confused you with someone else in my reply about the yahoo email address.
    This one is gone now. I didn't have much time to collect quotes this time. I'll try to get the RFQ out at least a week ahead of the deadline next time.
    Dave
  1. Drilled Holes Not Centered w/ Counterbore
    By tkalxx in forum Benchtop Machines
    Last Post: 11-30-2020, 05:03 PM
  2. S/F - Small holes in mild steel.
    By Wtz-44 in forum Material Machining Solutions
    Last Post: 06-25-2020, 04:30 PM
  3. Elongated Counterbore holes
    By cncnewbie68 in forum Autodesk
    Last Post: 11-22-2012, 01:50 AM
  4. Fast way to create bearing seats (holes w/ counterbore)
    By cjjonesarmory in forum Mass finishing equipment/media/strategies
    Last Post: 11-18-2010, 03:54 PM
  5. Drilling small holes in Die steel
    By drk in forum MetalWork Discussion
    Last Post: 08-13-2008, 07:59 PM
