586,094 active members*
4,050 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > No A axis moves ? ( in post )
    Apr 2006
    439
    Hi Guys
    I am having some trouble with 4th axis rotary indexing .
    I have created a part that requires machining on 3 sides , I have created 3 different setups with the UCS 90deg apart. all seems to go well through the simulation. but when trying to output code I do not get any "A" axis moves. I have tried naming my setups the same and different. no change.
    What I did to get the job done was uncheck "4th axis indexing" and outputted 3 different chunks of code and "stitched" them together with the appropriate A moves.
    I have tried several post processors as well...No A axis moves.
    I am sure that I am missing something...
    Any help would greatly appreciated !!
    Scott
    Feb 2004
    41
    Are you using the 4 axis post?
    Aug 2007
    4
    Scott,
    In your stock properties there is a checkbox to generate your g-codes for all setups in one file. Let me know if this fixes your problem.
    Tony
    Apr 2006
    439
    Hi Guys
    Thanks for your replies !
    I left a reply last night...I don't know where it went ????
    It went something like this.....
    Nevermind....I'm an Idiot
    I was not using a 4-axis post. (nuts)
    Anyway..
    I found a FADAL post that seemd pretty close
    I edited Program start , End and Tool change. Now it looks pretty good.
    I am running Mach 3 on a Tormach , I will test the post shortly and report back.
    Thanks again
    Scott
  1. Converting G2 & G3 Moves to Rotary Axis?
    By skibbey in forum G-Code Programing
    Last Post: 04-03-2007, 01:40 PM
  2. Changing Z moves
    By Davidimurray in forum Post Processors for MC
    Last Post: 02-10-2007, 08:59 PM
  3. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
  4. Z position moves up during run
    By henryj1951 in forum Gecko Drives
    Last Post: 03-28-2006, 12:16 AM
