586,076 active members*
3,971 visitors online*
Results 1 to 6 of 6
    Mar 2021
    7
    Motors move only in manual. What am I missing
    hi guys,
    I have replaced my breakout board back to a simple parallel one.
    Got everything connected and when I'm using the pendant motors are working fine.
    However, gcode (both from a file or using the mdi window) does not work.
    Instead of moving the axis the motors just squeak but not rotating at all.
    I tried to lower the pulse/rev on the driver and respectivly, on the motor setup window, but the result is the same.
    Btw, keyboard arrows in the motors setup window works fine.
    What am I missing?
    Tnx
    Apr 2005
    304
    Re: Motors move only in manual. What am I missing
    Lower acceleration. Start from there.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Lower the feedrate in the g-code also
    Mar 2021
    7
    Quote Originally Posted by ZASto View Post
    Hi, I did... it doesn't change
    Mar 2021
    7
    Will try it today but, it doesn't explain or solve the gcodes commands in the mdi and diagnostics tabs so I guess there is another thing unsolved..... ????
    Jan 2021
    27
    I also had that problem. Was able to job around but it would do what yours is doing with MDI.
    After some ass scratching, I remembered aboot the keyboard TAB button motion screen Jog %. So I changed it from 50% to 100% and then did the motor tuning, also making sure to press the speed and accel sliders before hitting the save settings button, finished and closed the motor tuning - then hitting save settings in the config menu - Then shutting down and restarting Mach 3.
    I got tired of trying over and over with small settings. So I did a big jump down in the speed / accl and worked my way up.
    I was never able to tune the motors from inside the motor tuning screen.
    Oh Don't forget to lower you jog rate back down
    If that helped -- please press the like and subscribe buttons... And I will see you next time
  1. Missing Steps on manual Jog
    By RC3Rob in forum PlanetCNC
    Last Post: 02-01-2021, 09:21 PM
  2. Missing information from HPR 130 XD manual
    By Simonh1959 in forum Hypertherm Plasma
    Last Post: 04-14-2014, 06:19 PM
  3. my motors will not move!...help!
    By yezard in forum Stepper Motors / Drives
    Last Post: 03-21-2011, 10:04 PM
  4. motors will not move
    By Rods UP 9000 in forum Mach Software (ArtSoft software)
    Last Post: 12-19-2010, 03:23 AM
  5. missing section of manual
    By candylyn in forum Bridgeport / Hardinge Mills
    Last Post: 03-09-2007, 04:01 PM
