586,630 active members*
2,624 visitors online*
    Mar 2021
    Standard Zen Lead Screw size/specs?
    I have a standard lead screw 12x12 machine. What is the specification of the Standard lead screw? Not the F8 upgrade. The Zen forums are down, and the wiki didn't note the specification. Just trying to source an anti-backlash nut.
    Feb 2012
    4
    Quote Originally Posted by eekflyer View Post
    If I remember correctly (it’s been a while) I believe they are 8mm x 1.25mm
    Nov 2012
    1267
    Re: Standard Zen Lead Screw size/specs?
    I have a Zen clone, it came with M8x1.25 all-thread originally. Replacing those with T8 trapezoidal screws was one of the best things I've done to the machine.
    As for the anti-backlash nuts, it's very easy to make your own if you have at least somewhat working CNC machine. It uses two standard M8 nuts.
  1. Help me identify this lead screw size
    By jimmyaz in forum Benchtop Machines
    Last Post: 09-02-2016, 05:28 PM
  2. hf 8x12 lead screw thread size
    By ubaldc in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2010, 09:40 PM
  3. for engraving pcb which is a good thread size for the lead screw?
    By NickLatech in forum DIY CNC Router Table Machines
    Last Post: 01-18-2005, 03:37 AM
  4. Lead screw specs
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 10-14-2004, 04:25 PM
