586,123 active members*
3,433 visitors online*
Page 15 of 17 51314151617
Results 281 to 300 of 322
  1. #281
    Aug 2006
    269
    Re: Yet another epoxy granite mill
    Quote Originally Posted by suspension View Post
    I was wondering which sized screws you used? I have used M16 and M14 mostly for this but feel like they are too big.
    I used M12 all over. The only exception being the threaded rods that goes all through the casting, these are M16 and are used for lifting/rigging. I've placed these M16s so they align with the center of gravity og the castings and/or where they makes good sense to have lifting points.
  2. #282
    Aug 2006
    269
    Small update: Got the electrical cabinet mounted tonight:
    Attachment 498178 Attachment 498176
    ...it is mounted to rails to be able to be pushed in behind the enclosure of the mill and pulled out for "servicing". This enables me to have to mill against the wall and still maximize space for electronics...hopefully it will work :-)
    /Thomas
  3. #283
    Aug 2006
    269
    Any ideas for a name for the machine? I'm starting to detailing some of the enclosure parts and it occures to me that i haven't got a name for the machine....and waaaay to few backlit cutouts ;-)
    Ideas?
  4. #284
    Mar 2014
    1131
    Battal. Means "big" in Turkish.
    Sent from my MI 5s Plus using Tapatalk
  5. #285
    Aug 2006
    269
    Started to work on the electronics cabinet:
    Attachment 499226
    ...as with everything else on this project: Its kinda big and it kinda doesn't fit:-)
    I have a lot of terminals, contactors, breakers etc coming in the mail within a couple of days, then it will started to get crowded :-/ Might have to choose some narrower cabletrays to get all the rows to fit...
  6. #286
    Aug 2006
    269
    I think i got room for everything for now:
    Attachment 499654
    ...there is still room for 4th and 5th axis drivers next to the line-filters...i hope :-)
    Next up: Wiring!
  7. #287
    Apr 2008
    127
    Quote Originally Posted by badhabit View Post
    I finally had the chance to assemble the entire tool-release with everything and test it out. And it works!
    So the whole problem is my height-contraint, otherwise i'd used a pneumatic cylinder. I also had to center the push-ring on the spindle AND make space for the coolant-through-spindle adapter on the end of the spindle. All while pushing 40.000N/4000kgf on the spindle. I was concerned that the push-ring would drag on the spindle so i built a "tower" to make the whole assembly more ridig and i added fixtures to the push-arm to keep it in line with the spindle...
    But i think i nailed it and i'm very pleased with the result :banana:
    ....on to the next problem :-)
    Great solution! With a smaller reservoir, you would likely achieve even faster and smoother unlocking. Where did you acquire this pump, and how much did it cost?
    I have a similar issue with my machine, as it also features a hydraulic unlocking mechanism, but lacks the necessary hydraulic system.
  8. #288
    Aug 2006
    269
    Quote Originally Posted by lukahr View Post
    The pump is an "air to hydraulic pump" from https://www.amf.de/en/ with article no. 6904-25, you'll also need a valve to release it, i chose 6904-52. Finally you need a cylinder that matches the required stroke and pressure. I chose 6926-78-002 for my application, but it all depends on your setup, so you'll need to do your own calculations on this...
    I'm pretty happy with the result. The speed of the release matches what my calculations say, around 1,5-2seconds. I'd like it to be faster, but then it would get A LOT more expensive since i have to use another type of pump(actually two electric pumps!) to get it faster at the pressure i need. Or i should add more pneumatic pumps, but then i run out of air.....in the perfect world the hydraulic release mechanism should have been integrated into the spindle, this would have required a lot less space and been much more effecient/"clean" and likely a lot faster too... but my world isn't perfect and i have to work with what i got ;-)
    Pricing is a bit hard to say since "i know a guy", but AMF isn't exactly cheap. I think the listprice would be somewhere around 2.000Euro for the lot, but check with your local reseller. Or maybe look for cheaper alternatives for similar components...
    /Thomas
  9. #289
    Aug 2006
    269
    A little progress on the electrical part of the project:
    Attachment 501228
    ...might look a bit messy without the covers on, but looks very tidy when they are mounted:-)
    The panel is like 95% done. I'm still waiting on a few things in the mail, but i've been running tests with LinuxCNC and so far everything works as expected.
    I also had to upgrade the electrical supply. So now the machine will have a dedicated 3-phase 400V/32A circuit with a TypeB RCD. Thats 22kW for making chips....they better be blue!
    Next up: Finish the panel, finish the testing, mount it in the controlcabinet and wire the gazillion cables to the panel....and then....profit?!
    /Thomas
  10. #290
    Aug 2006
    269
    As part of getting the electronics in order, i'm trying to figure out how i'd like the control interface....and honestly...i have no clue :-)
    So, i'm making a simple "version 1" and then i'm not going to make it too fancy, then it is easier to justify a redo down the road :-)
    This is my setup so far i CAD:
    Attachment 501358
    From the left it is Cycle Start / Feed hold below Feed override and spindle override. Then a jog-wheel with axis selection above(XYZ + future AC + spindle) and then multiplier(x1, x10, x100) to the right of the wheel. then a 4x4 set of utility buttons. Not sure what i'm going to use those for yet, but it could be stuff like coolant etc if i want a fast button for that or maybe just a dedicated light for something...and then estop and estop reset to the right...
    All the square buttons are momentary buttons with light.
    It is going to be 2mm steel plate which will be lasercut, bend and then welded in the corners. A plate can then be screwed onto the bag. It will be hanging from an arm going back to the column on the machine... not sure if that is the best idea ever, but i'll start with that and then V2 might just hang on the front of the enclosure...at some point :-)
    /Thomas
    /Thomas
  11. #291
    Apr 2008
    127
    uh....this arrived just today....
    Attachment 467806
    ...things are really coming together now...
    Have you played with this tool changer ? Where did you order it ?
  12. #292
    Aug 2006
    269
    No, not yet :-( But i have moved it around many times since it arrived because it is always in the way of something ;-) But hopefully VERY soon as the electronics is almost done and i'd like to test it...
    I bought it from CTB where i also bought the servos and the linear rails....they helped source it...
    /Thomas
  13. #293
    Aug 2006
    269
    The controlpanel starts to take shape:
    Attachment 502186 Attachment 502188 Attachment 502190
    ...next up: buttons and a ton of wires!
  14. #294
    Mar 2021
    41
    Nice
  15. #295
    Aug 2006
    269
    Waiting for CycleStart/FeedHold and potentiometers(for feed/spindle overrides) in the mail...everything else got mounted:
    Attachment 502244
    ...its starting to look like something now :-)
    A couple of evenings of wiring and it should be good to go...
  16. #296
    Aug 2006
    269
    Got the controlpanel wired up:
    Attachment 503516 Attachment 503518
    ...now i just need the mounting arm for it...and attach the backplate :-)
    ...on to the next part: finish wiring the main electronic enclosure!
  17. #297
    Aug 2006
    269
  18. #298
    Sep 2016
    353
    Hi Thomas
    Planning to put an order from china for the T table. To reduce the shipping cost, wanted to make sure all remaining stuff is included in this order. Main things missing for me are electrics, T-table, way-covers, vibration absorbing wheels, air tank and may be few more items. I see that you have a fairly comprehensive electronics/electrical setup. Any possibility to let me know what electrical/electronic parts are needed apart from stuff like motor controllers - which are part of the motor.
    Also, you were planning on running some EM tests on epoxy? Did you do that? These days I am waiting for my second sample made of Sika grout
    Sus
  19. #299
    Aug 2006
    269
    Impressive planning! I've used soooo much money on shipping because i almost ordered each part individually...and sometimes the same part twice because i broke it the first time ;-)
    Apart from the motors/servoes you'll need to consider:
    - Cables, quite expensive part of the build actually! I got something like 78 different cables(most 4-wires shielded) running into the eletrical cabinet...it adds up!
    - Enclosure, i recommend Rittal but due to size constraints i went for a Scheider Electric cabinet
    - Depending on the quality of your servodrives you might want to consider line filters to reduce EMI
    - Consider emergency stop functions. I bought an ABB safety relay and redundant safety contactors.
    - Do you need pneumatic or fluid valves? Might worth considering aswelll
    ...likely a ton of other stuff aswell, i'm not as good with planning as you apparently :-D
    Yes! Finally! I actually started on the forms for creating a test-billet last week...going for 40x40mm square and 800mm long billets... might finish the forms this week...
    My plan was to create 3 testbillets for the "first round" of testing:
    - 1. The same mix as mine, no additional treatment
    - 2. As with #1, but postcured at 70c for a week
    - 3. As with #1, but cured under pressure(8bar) to minimize/eliminate airbubbles
    I'll post about it where when i get to it :-) And maybe try to create a video about it...
    /Thomas
  20. #300
    Jul 2018
    6341
    Hi Thomas - How are you going to pressurise the sample to 8bar? do you have an autoclave? 8 bar is 80 tonne per sqm.. or do you have a big pressure pot? or a big steel tube I suppose.... I don't think eliminating internal bubbles will make a measurable difference? but you will find out... You can compress bubbles but then you trap micro bubbles at pressure in the concrete and they break out eventually. In aerospace laminates they are compacted at 6-8bar but the air goes into the resin as a saturated gas. Then as the part is cured at 120C it desorbs out, plus there is a vacuum system to remove gases....So you will need a plastic bag around the concrete part with a breather layer then 7 bar applied to the outside of the bag to pressurise the part....???? Regards Peter
    at 8bar a 2mm bubble will be compressed to a 1mm bubble so is this a difference? will be interesting to find out...
  1. Large Epoxy Granite Vertical CNC Mill
    By petruscad in forum Vertical Mill, Lathe Project Log
    Last Post: 10-08-2022, 10:45 PM
  2. Epoxy granite vertical mill cnc
    By bzaz in forum Vertical Mill, Lathe Project Log
    Last Post: 12-28-2017, 10:08 PM
  3. Epoxy granite CNC mill inspiration
    By IIIDMeister in forum Epoxy Granite
    Last Post: 02-16-2017, 07:48 PM
  4. Stab at a design for an Epoxy Granite Bed Mill
    By medu2015 in forum Vertical Mill, Lathe Project Log
    Last Post: 07-16-2016, 01:54 PM
  5. Epoxy Granite enhanced LMS SX2 CNC mill
    By SwampDonkey in forum Benchtop Machines
    Last Post: 05-01-2012, 07:05 PM
