586,058 active members*
4,522 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Need help converting From 6040 MKS4-V to AXBB-E
Results 1 to 6 of 6
    Jan 2021
    6
    Question Need help converting From 6040 MKS4-V to AXBB-E
    im trying to convert a control box from chinacnczone to use the AXBB-E controller .
    it has the mks4-v in it now .
    here is a few photos inside .
    any idea what all needs to be done ?
    i have no idea weather to just switch boards and match wires to same places .
    or if there is much more involved .
    my existing setup works . i just hate mach3 ....
    Quote Originally Posted by dezsoe
    There's no problem with the AXBB-E: it needs 5V for the logic side and 24V on the controlled side. The 24V can be 5V to 24V, depending on your needs.
    Reading the PDF you linked, it turns out that the MKS needs no power supply: it uses only the 5V from the USB. It generates the controlled side power with a DC-DC converter.
    To replace the MKS the AXBB-E seems to be the best choice, but you need the 5V supply and another for a higher voltage. The photos are so low resolution that I can hardly see anything on them. Can you take some useable photos? And also, open the lid on the VFD to see those cables too. Are the limit sensors simple micro switches?
    (I can't see if the red cable is connected to the 5V output, where the 4th axis' cable goes, etc.)
    well i unbolted the existing board so i could see where the 4th axis was going and this is what i see .
    https://drive.google.com/file/d/1O3w...ew?usp=sharing
    seems 4th axes goes into this box and this box is supplied 24volt from the internal power supply .
    the other side of the box goes to the mks board where one of the wires is connected to a port marked +5v
    shown here
    https://drive.google.com/file/d/1O6k...ew?usp=sharing
    tested the internal power supply the grey box it supply's 24.5vdc .
    https://drive.google.com/file/d/1Nv7...ew?usp=sharing
    here is the VFD with the lid off
    https://drive.google.com/file/d/1Ncq...ew?usp=sharing
    here is one of the stepper drivers .
    https://drive.google.com/file/d/1Nv2...ew?usp=sharing
    the limit switches are just micro switches .
    6 switches in total i believe .
    Attached Thumbnails Attached Thumbnails photo (3).jpg   photo (5).jpg   IMG_20210303_124022.jpg   IMG_20210303_124103.jpg
    Jan 2021
    6
    Re: Need help converting From 6040 MKS4-V to AXBB-E
    more photos .
    also removed the little device that was connected to the 4th axis .
    the one with the clear cover so i could get a better photo with lid off .
    seems its a
    JP-1635A
    Attached Thumbnails Attached Thumbnails IMG_20210304_133634.jpg   IMG_20210304_135758.jpg   IMG_20210304_135743.jpg   IMG_20210304_134152.jpg
    IMG_20210304_133712.jpg   IMG_20210304_133548.jpg   IMG_20210304_133617.jpg   IMG_20210304_133628.jpg
    Jan 2021
    6
    Jan 2021
    6
    more photos
    Attached Thumbnails Attached Thumbnails HTB1TJSzPXXXXXaYXVXXq6xXFXXXn.jpg   HTB1ZJeEPXXXXXXsXVXXq6xXFXXX8.jpg   HTB1CyyOPXXXXXavXFXXq6xXFXXXg.jpg
    Jan 2021
    6
    ordered one of these to get my 5v for the AXBB-E
    Attached Thumbnails Attached Thumbnails 61dSqz9nysL._AC_SL1200_.jpg   61bM7R5NNTL._AC_SL1200_.jpg
    Jan 2021
    6
    Hope Someone Can help .
    no idea where to start .
