586,260 active members*
3,053 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > How do you cut square inside coners?
Page 1 of 3 123
Results 1 to 20 of 42
    May 2007
    125
    Ok, I am haveing fun learning my new machine a CNC Taig. But now I need to start making parts. How do you machine a square inside coner?
    24221
    One method, which depends on whether you can tolerate it cosmetically, is to use a small diameter tool for the final finish on the outside of the pocket, and when the corners are reached the tool moves out a small distance at 45°, just enough to take out the normal radius that is left.
    This depends alot on your application.
    Al
    Albert E.
    May 2007
    125
    Al
    I`m not sure I understand how that works?
    24221
    IOW if you used, say a 1/8" endmill to get the corners as close as possible to a right angle, then move outward from the corner at 45°, this causes a small semicircle out from the corner, if you were making a pocket for a rectangular item to fit into, this would relieve it enough for it to drop into, this is one method I use to, but maybe not pretty.
    Al.
    Albert E.
    Jan 2004
    3154
    Quote Originally Posted by Astroguy View Post
    You CAN'T
    Al's method is a workaround to allow a square part to fit through the aperture.
    Square holes are made by broaching, EDM or filing.
    www.integratedmechanical.ca
    Apr 2005
    1778
    If you mill around the inside of the square with a 2" diameter tool, it leaves a 1" radius in the corner. The distance from the edge of the tool to the corner of the rectangle is the ((square root of (1^2 +1^2 )) minus 1) or the square root of 2 - 1 which is approximately 0.414". So when the tool is tangent with both side of the corner, you could move on a 45° towards the corner to remove the remaining material from the corner. Of course the smaller the tool that is used the less the deviation from square.
    May 2007
    125
    Al.
    Duh, OK now I see. Thanks guys, I have learned so much here.
    Dec 2005
    93
    We call those corners "mouse ears". They work fine in the mold business.
    Mar 2007
    534
    ...or, you could use a square hole drill, I kid you not
    http://www.integerspin.co.uk/polygon.htm
    Sep 2004
    218
    Darebee is right squared corners are made with broaching cutters, EDM's or filing.
    You could try to cut the pocket and then come back with a smaller diameter cutter to lessen the corner radius but it will still require broaching or filing to get them truely square. If you can get the radius as small as possible first it lessens the amount of filing needed to square things up.
    Bowman
    Apr 2005
    1778
    Astroguy,
    I guess the real question now is ,"Do you really need square corners, or do you need a hole that something square will fit into?
    Alan
    Oct 2006
    44
    Maybe he just needs a deliberate stress raiser
    Feb 2007
    4
    go old school try a shapper
    Aug 2007
    15
    I was curious about this myself because I wanted square corners for a project I'll be working on. After doing a ton of research this morning, it looks like there is a company that makes the Square Hole drill bits, but they recommend that you only go 2x the size of the square for depth. They are sending me a catalog, so I'm going to check it out and will report back with any findings.
    Oct 2005
    612
    Have a look at the part you are mating to the pocket and see if it is easier to radius the corners to match the pocket.
    cheers,
    Rod
    Perth, Western Australia
    Aug 2005
    385
    EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
    Experts in low volume, highly complicated, one-off forged aluminum wheels
    Mar 2006
    2712
    I bet that's why they made the slotting/broaching attachment for BP's.
    Then there is tilting/swiveling the head at a compound 45 deg. angle with a 90 deg. incl. angle end mill (ground to sharp point). Don't think it applies to the Taig CNC though.
    I'd vote for the corner broaching if a true square corner is required.
    DZASTR
    Dec 2005
    3319
    Square holes can be rather sexy - they can also be great sharp cornered places for cracks to start propogating from. This is especially true in material that is to be subsequently hardened and/or moderately/highly stressed.
    The "how to" make a square hole has already been discussed. However, the best way to prevent the square hole from causing problems later is to use the round hole in the corner trick.
    Moreover, by doing this, any torque applied to the part thru the hole applies the foce into/thru the "flat drive" method - Snap-on made a lot of money selling wrenches and sockets that use this trick and it is also used in fits-all combo/metric-imperial wrenches that show up in TV telemarketing ads.
    The reduced stress concentration from the rounded corners provides a lot of incipient charm as opposed to a sexy but "why bother" truly square hole.
    Mar 2007
    534
    Quote Originally Posted by Skyshark View Post
    If you get one working you will post lots of pics won't you, maybe a movie?
    I think it will only drill, won't round out a corner. Looking at the theory I think the tip needs to bite in to metal to keep it on track corner to corner
    The Mouse-ear trick is the most commom used method to create square or rectangular holes.. i must stress though, EDM is used to make em, BUT!!..WITH "mouse ears, because an EDM wire still is 0.25 mm thick in most cases, creating a 0.32 mm wide cut, thus a 0.16 mm corner radius...
    slightly bigger is better, we'd make 1mm holes on the corners at least..
    Stress relief is important here..
    a hole can really prevent a crack, it's an old trick used by motorcycle racers, when after a crash the windshield was cracked, simply drill a 4 mm hole at the end of the crack, and the crack won't crack any further..
Page 1 of 3 123
  1. The wiring inside a control box...
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 06-02-2007, 06:13 PM
  2. Diameter of inside cut, too small
    By SVM in forum Uncategorised CAM Discussion
    Last Post: 06-19-2006, 03:17 PM
  3. inside turning
    By Nine in forum MetalWork Discussion
    Last Post: 02-16-2005, 05:33 AM
  4. Can someone help me with gcode or cad/cam(3dfigures inside)
    By HawainPand in forum Employment Opportunity
    Last Post: 09-11-2004, 04:34 PM
  5. What's inside this box?
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 03:07 AM
