586,111 active members*
3,215 visitors online*
    Mar 2021
    bridgeport series 1 interact TNC 145 DOA
    My boss has purchased the above machine. We viewed the machine prior to purchase and it was working.
    Had the machine delivered and put in its new spot. Put power and air to it, turned it on and power interrupted came up on screen. Pressed CE button and it comes up with pass over x and y reference points ( if memory serves) but controls are dead.
    When I last used one of these machines, we had to reinput the parameters for the machine but the book that came with machine doesn't have them written down and for the life of me can I remember how to put them in.
    Any help would be much appreciated on. I did do a search on here, saw numerous posts about parameters, but not been able to download them or view them.
    1121
    Re: bridgeport series 1 interact TNC 145 DOA
    It has the parameters
    you need to hit power enable button after CE
    You should then hear the drives enable and it should move
    if it not asking for parameters then it still has them, once you get the pass over on screen you should press the reset controls button (power enable) and the start cycle button for each axis,
